[snappyHexMesh] Surface geometry with snappyHexMesh
Old   April 1, 2016, 13:12
Default Surface geometry with snappyHexMesh
Michal
miku11 is on a distinguished road
I'm writing with a question - is it possible to use as an obstacle a surface - i mean STL geometry bul only surface, not solid and create a mesh using snappyHexMesh?
Does anybody have an experience like this and can tell me how to do that?
Best regards
miku11 is offline   Reply With Quote
Old   April 2, 2016, 02:33
akidess's Avatar
Anton Kidess
You should look into the usage of "baffles".
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh crizpi21 OpenFOAM Meshing & Mesh Conversion 5 October 16, 2021 10:56
[snappyHexMesh] snappyHexMesh will not delete bounding box AlexanderMath OpenFOAM Meshing & Mesh Conversion 2 November 8, 2016 02:11
[snappyHexMesh] problem with snappyHexMesh kanes OpenFOAM Meshing & Mesh Conversion 10 January 26, 2016 06:11
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 05:26
[snappyHexMesh] snappyHexMesh - backward facing step hcl734 OpenFOAM Meshing & Mesh Conversion 4 November 20, 2015 09:57
