[snappyHexMesh] Problem with parallel run of snappyHexMesh |
April 11, 2016, 06:15 |
Lorenzo
Rep Power: 10 |
Hi everyone,
my problem is the following: I have to run SHM on a given geometry and I wanted to execute it in a parallel run with mpirun. After the meshing is successfully done , I use reconstructPar -latestTime but when I perform this stage I get to a rather long list of warnings concerning lacking directories and libraries , which eventually end up with a Fatal Error. It is quite strange since when the very same meshing is performed without parallelization, then no error occurs. I would be grateful if anyone can give me a hint on what is going on, and maybe help me sort it out. Thanks Here the copy of the error statement after meshing on two processors has been terminated: Finished meshing without any errors Finished meshing in = 321.52 s. End Finalising parallel run /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : reconstructPar -latestTime Date : Apr 10 2016 Time : 14:25:37 Host : "user-X555LAB" PID : 2716 Case : /home/user/Documenti/Lorenzo/Materie_quinto_anno/Tesi_Les_Naso/Manara_Copia/DeltaPTot nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libswak4FoamParsers.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libswak4FoamParsers.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libsimpleSwakFunctionObjects.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libswakFunctionObjects.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libgroovyBC.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libgroovyBC.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libswak4FoamParsers.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libswak4FoamParsers.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libsimpleSwakFunctionObjects.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libswakFunctionObjects.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libgroovyBC.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libgroovyBC.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libswak4FoamParsers.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libswak4FoamParsers.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libsimpleSwakFunctionObjects.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libswakFunctionObjects.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libgroovyBC.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libgroovyBC.so" Reconstructing fields for mesh region0 Time = 0.0003 --> FOAM Warning : From function polyMesh::readUpdateState polyMesh::readUpdate() in file meshes/polyMesh/polyMeshIO.C at line 207 Number of patches has changed. This may have unexpected consequences. Proceed with care. --> FOAM Warning : From function polyMesh::readUpdateState polyMesh::readUpdate() in file meshes/polyMesh/polyMeshIO.C at line 207 Number of patches has changed. This may have unexpected consequences. Proceed with care. --> FOAM FATAL IO ERROR: cannot find file file: /home/user/Documenti/Lorenzo/Materie_quinto_anno/Tesi_Les_Naso/Manara_Copia/DeltaPTot/processor0/0.0003/polyMesh/pointProcAddressing at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting |
April 12, 2016, 02:45 |
Rep Power: 15 |
You might want to try first with reconstructParMesh and then use reconstructPar. Hope this helps. Cheers, Antimony |
April 12, 2016, 08:53 |
Lorenzo
Rep Power: 10 |
It works now, thank you very much Antimony!
For the sake of clarity I just launched reconstructParMesh and then reconstructPar -latestTime. But now I don't know what the two commands separately do, I thought to use reconstructPar-latestTime in order to reconstruct the meshes created by the two processors ( at the end of the latest time step, in my case correspondent to the layer addition). Please correct me if I'm wrong. |
April 13, 2016, 02:07 |
Rep Power: 15 |
You are welcome! As far as I understand it and have used it, reconstructParMesh puts the meshes together, but not the fields, which is taken care of by reconstructPar. (http://cfd.direct/openfoam/user-guid...ard-utilities/) Cheers, Antimony |
April 14, 2016, 15:50 |
Lorenzo
Rep Power: 10 |
So after having run my analysis in parallel mode I should reconstruct also the fields of pressure and velocity of course using reconstructPar.
Thanks a lot again!! |
April 15, 2016, 04:12 |
Rep Power: 15 |
You are welcome! Actually, if you want you are going to analyze your results in Paraview, you don't need to reconstruct. You can simply choose the "Decomposed Case" in the Case Type and you are good to go. Cheers, Antimony |
Some questions about a multi region case run in parallel | zfaraday | OpenFOAM Running, Solving & CFD | 5 | February 23, 2017 10:25 |
[snappyHexMesh] SnappyHexMesh in Parallel problem | swifty | OpenFOAM Meshing & Mesh Conversion | 10 | November 6, 2015 04:40 |
Problem in parallel run with OpenFOAM | Gitesh P | OpenFOAM Running, Solving & CFD | 2 | June 1, 2014 06:05 |
[snappyHexMesh] snappyHexMesh parallel run error | dhruv | OpenFOAM Meshing & Mesh Conversion | 2 | February 16, 2012 04:34 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 17:11 |
