[snappyHexMesh] mesh related problem with high courant-number at edge
Old   April 20, 2016, 09:16
Question mesh related problem with high courant-number at edge
mo_na's Avatar
Mona
mo_na is on a distinguished road
Hi everyone,
I am trying to simulate a pitching floater in a numerical wave tank in 3D. I am using ihDyMFoam and a dynamic Mesh.
One edge of the floater is curved. SnappyHexMesh is creating quite skew faces here, which I am not able to remove. If I lower the values for maximum skewness in the meshQualityControls I get cells that stick out and can't be snapped in again with snapEdge. Making the refinement on the surface coarser or finer also doesn't change the situation.
The problem that I am facing now are quite big courant-numbers only in these cells (See attached picture) . And this happens already after 0.2 seconds, so long before the wave is supposed to hit the floater. Right now I am using a timestep of 0.001 s and I don't really want to lower it just because of these few cells.
Does anyone have an idea how to deal with this problem?
Thanks for you help!
Cheers,
Mona
mo_na is offline   Reply With Quote
Old   April 20, 2016, 10:35
Default Update
mo_na's Avatar
Mona
Update: After 0.47 seconds the courant-number explodes and the simulation crashes. I think its because of this one cell on the corner that you can see in the 2nd picture at time 0.45.
Old   February 23, 2017, 07:21
Svensen is on a distinguished road
Did you find any solution ?
Svensen is offline   Reply With Quote
Old   February 23, 2017, 07:47
mo_na's Avatar
Mona
Kind of... I am simulating in quasi 2D instead now. So I am just using a thin slice of the body. It was much easier to achieve good mesh quality in that way, and its faster
courant number, ihdyfoam, snappyhexmesh
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
