[snappyHexMesh] snnapyHexMesh error when meshing 6-sided wedge shaped |
May 17, 2016, 13:11 |
Eduardo Firvida
Rep Power: 15 |
Hi I'm trying to create a mesh of this case using snappyHexMesh but always give me the same error, in the refinement step, is there anyway to bypass this error?
cell 2 of level 0 does not seem to have 8 points of equal or lower level cellPoints:6(2 3 18 19 34 35) pointLevels:6{0}true https://www.dropbox.com/s/n3tkvfm5e6...test2.zip?dl=0 |
May 17, 2016, 20:55 |
Rep Power: 15 |
As far as I have seen, snappy works only with an initial pure hex mesh. The presence of any other type of cells in a mesh results in the type of errors that you have mentioned. Hope this helps. Cheers, Antimony |
Meshing a quasi-2D cylindrical wedge | evcelica | CFX | 2 | January 10, 2013 08:51 |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 00:35 |
[Other] Meshing Techniques for Heat Transfer with Cube Shaped Objects | cbritan | OpenFOAM Meshing & Mesh Conversion | 4 | March 2, 2011 01:12 |
[blockMesh] Problems meshing wedge type blocks | Alan | OpenFOAM Meshing & Mesh Conversion | 0 | July 27, 2009 20:05 |
