[snappyHexMesh] Multi region meshing with SHM creates extra regions
Old   August 8, 2016, 08:54
Default Multi region meshing with SHM creates extra regions
Dav3dum is on a distinguished road
Dear Foamers!
I'm trying to mesh a heat exchanger with SHM and whenever i try to rifne the mesh I get extra regions named domain0 ,domain1 and so on. I figured it out that the number of these extra regions depends on the refinement level.
The STL I use is imported from Inventor
I gladly welcome any tip/solution idea about this issue.
Your sincerly
David
Dav3dum is offline   Reply With Quote
chtmultiregion, domain, shm
Part based meshing VS Region based meshing Bharatt STAR-CCM+ 6 February 21, 2018 07:43
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 05:09
[snappyHexMesh] Multi Region Meshing bruce OpenFOAM Meshing & Mesh Conversion 12 July 31, 2013 10:09
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
