Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
jagged, ragged edges...
Old   December 8, 2010, 08:45
Robert Ong
rob3rt 0ng is on a distinguished road
I have a rather stupid question. When I type in snapEdge, it gives me an error message saying it can't read the designated stl file name. I'm sure the name of both the one in the snapEdgeDict and triSurface is the same. Sorry for posting up this question in this forum, as there is no other where else in the forum disccusing this matter.
Kind Regards,
Robert
rob3rt 0ng is offline   Reply With Quote
Old   December 8, 2010, 08:56
Arne Stahlmann
Arnoldinho is on a distinguished road
For snapEdge, the stl files must be in the main case directory (together with 0, system, constant etc.). So just create a link to the triSurface folder, or simply copy the stl files.
Arnoldinho is offline   Reply With Quote
Old   December 20, 2010, 17:51
Gonzalo Tampier
gtampier is on a distinguished road
amazing tool. I've been working with several "tricks" trying to solve the snappy problem with sharp edges... but only very specific and time consuming solutions!
I've been trying to download snapEdge.tgz for many hours w/o success from the openfoamwiki.net link (http://openfoam.nequam.se/cases/snapEdge.tgz). Is it a temporary problem or is there a new link or mirror somewhere?
Thanks in advance,
Gonzalo Tampier
gtampier is offline   Reply With Quote
Old   December 21, 2010, 02:10
niklas's Avatar
Niklas Nordin
niklas is on a distinguished road
The link is permanent.
Works fine for me.
niklas is offline   Reply With Quote
Old   December 30, 2010, 13:58
Default small orifice in a very large room
  #125
namCFD is on a distinguished road
Hello Niklas,
I am trying to use snappyHexMesh and snapEdge to insert a very small orifice (9mm diameter & 10 cm long) inside a very big room (20m L x 8 m H x 10 m W). My goal is to use dieselFoam to simulate water droplet distribution with incoming gas from the orifice (inlet) to increase the initial momentum of the droplets. Without the incoming gas, the initial/injection droplet velocity is about 6 m/sec. The incoming gas is about 340 m/sec. With the gas, the initial droplet velocity increases to about 160 m/sec. Improved momentum increases the distribution distance and area. I get this by placing the injector in front of the orifice/inlet. Basically, I combine your ammonium problem with aachenbomb.
I am new to all this snappyHexMesh and snapEdge, in particular, and OpenFOAM/dieselFoam in general. I have a few questions:
1) Is this a hopeless case since the orifice/inlet is sooo small as compared to the room dimensions that the mesh will never work out? Using checkMesh fails all the time.
2) What files after snappyHexMesh and snapEdge must I use to run the case?
3) Is there away to use dieselFoam solver and the injector to inject both gas and liquid at the same time? What must I modify if injecting both gas and liquid is possible?
Thank you for your help.
Nam
Nam
namCFD is offline   Reply With Quote
Old   December 30, 2010, 14:04
Default Forget a file
  #126
Oops, I forget to include the snappyHexMeshDict.
Nam
Old   March 10, 2011, 15:40
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Great job! Thanks, Niklas.
Well, will snappyHexMesh next release includes your snapEdge feature?
I am meshing a building case, that is flow around building, and snapEdge works very good, though I still need help to improve the mesh quality.
Daniel WEI
NatHaz Modeling Laboratory
Department of Civil Engineering and Geological Sciences
University of Notre Dame
Email || my-personal-website || my-New-CFD-Blog
lakeat is offline   Reply With Quote
Old   March 11, 2011, 01:39
niklas's Avatar
Niklas Nordin
Nope, I would not recommend it either. Its by no means a finished product and it works
quite slow and only on 1 processor.
I am using it on a daily basis though for which it does exactly what I want and that is
to get a correct inflow/outflow area on pipe-flow simulations.
Old   March 18, 2011, 12:21
Default snapEdge
  #129
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Hi Nikalas,
Have you ever tried to addlayers after using snapEdge. I feel like I have a problem adding layers after snapEdge. I don't have much experience with sHM but my aim is to create a mesh that captures the edge features well.
Problem
: After using snapEdge when I try adding layers, I see a very strange kind of behavior. Like some kind of baffles being created on surfaces and some sort of hanging cells. I was curious if anyone has seen you have ever seen this kind of behavior before and found any solution.
Regards,
Awais
owayz is offline   Reply With Quote
Old   March 18, 2011, 12:38
lakeat's Avatar
Daniel WEI (老魏)
Hmm, I forgot to report, that last time, a week ago, when I used snapEdge, and then, the simulation went wrong, floating points exaception, I think it is something related with snapEdge. But Im not sure
Daniel WEI
Old   March 25, 2011, 13:40
Default SnapEdge and snappyHexMesh
  #131
usergk is on a distinguished road
Hi
I am a new user of OpenFoam and am trying to generate a mesh for a slightly complicated geometry involving swirler blades.
I tried snappyHexMesh on the stl file, and it seemed to work fine; however, I am getting a floating point error with snapEdge.
The files are attached. Could someone more experienced look at it and suggest how I may improve the mesh (using both snappyHexMesh and snapEdge)?
I would like a coarser mesh (to reduce computation time), so perhaps snapEdge could be a useful tool.
Many thanks,
GK
[Edit: zip file modified]
usergk is offline   Reply With Quote
Old   October 6, 2011, 16:45
Default snapEdge tested on OF 2.0.1?
  #132
Johannes N Theron
jantheron is on a distinguished road
Has anybody tested snapEdge on OpenFOAM 2.0.1? I have a sparseimage distro on my Mac and have been happy with all functionality working. I'd like to check that snapEdge has been tested before risking mucking up my precompiled OF with a recompile...
Jan
www.kanoefabrik.com
jantheron is offline   Reply With Quote
Old   October 6, 2011, 17:06
Ziad Boutanios
ziad is on a distinguished road
Jan
www.kanoefabrik.com
You should not need to use snapEdge on OpenFOAM 2.x. The ragged edges bug is apparently fixed in snappyHexMesh now.
http://www.openfoam.com/news/snappyH...ature-edge.php
ziad is offline   Reply With Quote
Old   October 6, 2011, 17:52
Johannes N Theron
Hmmm.. I must be doing something wrong, for my stl file and the resulting openfoam grid after snappyHexMesh are quite different. I attached pics of both as well as my snappyHexMeshDict. Is there something obvious you can pick up?
Old   October 7, 2011, 03:42
stephane sanchi
openfoam_user is on a distinguished road
Hi Jan,
you can try the flange tutorial:
OpenFOAM-2.0.x/tutorials/mesh/snappyHexMesh/flange
Following lines are needed to capture sharp edges:
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
file "flange.eMesh";
level 0;
Then you have to run surfaceFeatureExtract before snappyHexMesh.
runApplication surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/flange.stl flange
runApplication snappyHexMesh -overwrite
Regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   October 9, 2011, 03:20
Johannes N Theron
Stephane
Thank you! Lovely tip. Just one question: How would one visualize these edges that are produced?
Jan
Old   October 9, 2011, 06:59
Bruno Santos
wyldckat will become famous soon enoughwyldckat will become famous soon enough
Greetings to all!
@Jan: You can open the ".obj" files generated by surfaceFeatureExtract directly in ParaView, without any need for additional file conversion!
By the way, a thread where are already a few discussions about this new feature in OF 2.0 is this: snappyHexMesh feature edge
Best regards,
Bruno
Old   October 9, 2011, 18:50
Johannes N Theron
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Thanks, Bruno
Worked like a charm!
Jan
www.kanoefabrik.com
edges, jagged edges, snappyhexmesh
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM 21 February 27, 2010 03:47
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 19:43
setting boundary conditions on internal edges Renate Stump FLUENT 4 November 7, 2008 10:55
Edges in Gambit Naghman Khan FLUENT 3 October 3, 2007 06:36
Simple Meshed Edges Problem Rich Main CFD Forum 1 February 9, 2005 01:38
