-   OpenFOAM Native Meshers: snappyHexMesh and Others (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/)
-   -   snappyHexMesh stl file read problem (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/73468-snappyhexmesh-stl-file-read-problem.html)
joeholdsworth March 9, 2010 07:23
I am trying to use the motorbike sHM tutorial as a base point for my project.
I have replaced the motorBike.stl file with my .stl file which i renamed as motorBike.stl to avoid having to change the sHM dic file too much.
I then edited the sHM dic file making the following changes ...
1. // refinementBox i commented this part out for now
// type searchableBox;
// min (-1.0 -0.7 0.0);
// max ( 8.0 0.7 2.5);
2. locationInMesh (3 0 4); //this is so my model is in the middle of the mesh
3. layers // i'm not shore i changed this to the correct value..?
motorBike_OBJECT
nSurfaceLayers 1;
... "blockMesh" works fine..
then when i type snappyHexMesh i get this error...
while reading solid on line 275620
expected 'solid', 'color', 'facet' or 'endsolid' but found 'Point(1) = {0, 0, 0};'
From function triSurface::readSTLASCII(const fileName& STLfileName)
in file triSurface/interfaces/STL/readSTLASCII.L at line 369.
FOAM exiting
...help me!!.. :)
olesen March 10, 2010 03:35
FOAM exiting
...help me!!.. :)
I think it's a safe guess that your STL file isn't STL at all.
Take a look at your file and compare it to the STL format (http://en.wikipedia.org/wiki/STL_%28file_format%29), you'll see that it doesn't match.
The question is "what format do you actually have?"
joeholdsworth March 12, 2010 09:18
Hi Mark,
thank you very much for taking the time to reply...
You are indeed right, its funny becuase i could open my stl model using gmsh ok, so i assumed that the .stl file was fine.
Anyway the solution was to save it in gmesh again making sure stl format was selected, this worked.
squadron April 1, 2010 10:10
Some programs that create .stl's do not create the entries:
solid "name"
endsolid "name"
at the top and bottom of the file respectively.
Open the .stl file in a text editor and add these entries manually will solve the problem.
Other programs create wrong entries. Deleting them in a text editor will solve the problems.
If a .stl file is very large, you can write a script to delete or add required text.
desert_1250 June 25, 2011 03:29
can not open .stl
hello all
i have .stl file that created with MATLAB, but when i import it in GAMBIT or another visualized software such as NETGEN, STL viewer, dont appear any thing, why this happen?:( i am very confused:confused:
