[snappyHexMesh] snappyHexMesh: How can be avoided polyhedra |
March 18, 2010, 05:50 |
Claus Meister
Rep Power: 17 |
Hello Foamers,
certainly a simple question: How can I avoid that snappyHexMesh generates polyhedrai.e. I just want a purely mesh consisting of hexhedra. Cheers in advance! |
March 19, 2010, 09:34 |
refinement
mediode
Rep Power: 17 |
I am not too familiar with it, but I think you have to control the refinement. The refinment level should be even all over your domain. Another way would be to set a background mesh with your desired resolution and suppressing refinment totally, but the might create a huge amount of data.
cheers m+ |
September 25, 2013, 09:16 |
Filip Gjetvaj
Rep Power: 13 |
I need the same thing so just the information if you made some progress and if yes could you please describe how you did it?? Cheers |
September 25, 2013, 09:48 |
Rep Power: 19 |
Unfortuneatly I do not think that it is possible to avoid polyhedras all together when using sHM. It's just the way it works. Even tough you can avoid many polyhedras by specifying uniform mesh density outside your geometry, I think that it still produces polyhedras when cutting cells and snapping to surfaces.
Anyways, if you need a pure hex mesh you are better of searching for an alternative grid generator. I know that GridPro can make some really amazing block-structured grids, however, it require much user training. One small question: why do you need a grid withouut polyhedral cells? |
September 26, 2013, 05:12 |
Filip Gjetvaj
Rep Power: 13 |
Tnx Hakon, I actually need structured mesh because I need it later to implement my own code on it after calculating flow field in OpenFOAM
September 27, 2013, 06:35 |
Tobias Holzmann
Rep Power: 51 |
ANSYS-ICEM can build only hexaedral meshes too but it could be very difficult. Maybe the following tool will be good for your - depend on your geometry http://www.cfd-online.com/Forums/ope...a-release.html Regard Tobi |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
Strange Results With snappyHexMesh | calebamiles | OpenFOAM Running, Solving & CFD | 0 | August 14, 2011 16:02 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
