[snappyHexMesh] mesh withoutpolycells possible? |
June 29, 2010, 14:35 |
Peter Wiemeyer
Rep Power: 16 |
I've a mesh out of another program that contains only tets, pyramids, prisms and hex cells. During the layer creation process SHM makes some optimization of the surface and within this step polycells are created. Is there any option to avoid getting polycells or has somebody a workaround. Using another tool for creating the boundary layers may be an option as well. (I want to reimport the mesh to ANSA but ANSA unfortunately doesn't support polycells). Thanks & best Regards, Peter
July 6, 2010, 04:12 |
Vangelis Skaperdas
Rep Power: 21 |
Hi Peter,
Can you please tell me what you want to achieve? I understand you already have a volume mesh, so what do you want to do in SHM? Vangelis |
August 21, 2012, 05:25 |
Eloïse
Rep Power: 13 |
Hi Peter,
Have you found a solution to your issue? I also would like to avoid those cells in the layer. Thanks, Eloïse |
August 22, 2012, 05:58 |
Vangelis Skaperdas
Rep Power: 21 |
Just want to mention that you can indeed read in ANSA a polyhedral mesh created in SHM without a problem
Display Modes | |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
