-   OpenFOAM Native Meshers: snappyHexMesh and Others (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/)
-   -   Missing elements near surface with snappyHexMesh (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/80154-missing-elements-near-surface-snappyhexmesh.html)
jmf September 16, 2010 17:27
1 Attachment(s)
Hello everybody
I'm struggling to solve mesh quality problems on the surface of my model : small holes due to missing elements near the model surface.
These holes always occur near transition between patches with different levels
I attached
- a clipped view of flaw in volume
- a view of the surface (from inside the volume) with 3 flaws
- the snappyHexMeshDict
Is the smoothness of the mesh at the surface normal ? I think that it is poor...
I run OF1.7.1 on 64 bit Linux, compiled from sources
Any tip would be appreciated
Regards
J-Michel
jmf September 18, 2010 06:18
Missing cells near surface with snappyHexMesh
2 Attachment(s)
Hello
I go on investigating
This problem only occurs when surface is tilted compared with backgroung hex mesh. I tried 10 and 20 degrees slope. (image attached at 20 degrees)
With surface parallel to background mesh, snappy mesh is smooth (image attached)
The problem is the same with prebuild OF1.6 32 bits
Best wishes
jean-Michel
ziad September 22, 2010 23:07
Hi Jean-Michel,
Is your geometry smooth enough at these locations? Maybe you could increase the tessellation at these locations in the stl file. It could be a defect in the geometry file.
Otherwise it seems to be a snapping problem. How about increasing nSmoothPatch?
Try running checkMesh -latestTime to see if these elements are not contorted.
Ziad
jmf September 27, 2010 18:48
Hi Ziad
Thanks for your answer
I tried increasing nSmoothPatch without result. But then I tried systematic modifications of other Snappy parameters, and finally I found that maxConcave = 90 (instead of 30) solved my problem
Best wishes
Jean-Michel
ziad September 27, 2010 18:55
Originally Posted by jmf (Post 276844)
Hi Ziad
Best wishes
Jean-Michel
Thanks for posting the solution Jean-Michel. It's funny but the maxConcave parameter seems to be quite influent on the mesh. I managed to get a mesh without the ragged/jagged edges by reducing maxConcave to 1.0 and it's good to know that it can also fix this type of problems.
Cheers,
Ziad
Stylianos August 27, 2013 09:25
Thanks for the help guys
