Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
snappyHexMeshDict
Old   November 8, 2010, 10:23
Default snappyHexMeshDict
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am writing since I have a couple of questions about the snappyHexMeshDict file.
I can not understand 2 sections in that file and I can not find any explanation in the user's guide.
I am speaking about "pointsCheck" and "handleSnapProblems"..
Could you help?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   November 10, 2010, 03:43
colinB is on a distinguished road
which version of OF are you using?
For I'm using 1.7.1 and I don't have such parameters in my
sHMD and mine is working fine without them.
regards
colinB is offline   Reply With Quote
Old   November 10, 2010, 03:53
Samuele Z
Dear Colin,
actually, I am running the version 1.7, as well.
I attach below my sHMD.
Also, one more question about snappyHexMesh. I thought it was enough to create the blockMeshDict and the snappyHexMeshDict files, in order to be able to run "snappyHexMesh".
Indeed, I need 4 other files (e.g. controlDict, decomposeParDict, fvSchemes and fvSolution) that, imho, do not contain any info about the mesh generation. Where am I wrong?
Thanks a lot,
Samuele
Here is my sHMD:
// * Created by Francesco * //
FoamFile
    version 2.0;
    format ascii;
    root ".";
    case "";
    instance ".";
    local "";
    class dictionary;
    object snappyHexMeshDict;
castellatedMesh true;
snap            true;
pointsCheck     false;
addLayers       false;
debug           0;
handleSnapProblems on;
mergeTolerance  1e-6;
geometry
    "nasal_cavity.stl"
        type            triSurfaceMesh;
        name            cavity;
        tolerance       1e-3;
        regions
            patch0          { name nasalCavitySurface; }
castellatedMeshControls
    maxLocalCells   80000000;
    maxGlobalCells  160000000;
    minRefinementCells 20;
    nCellsBetweenLevels 3;
    features
    locationInMesh  ( -27.65 -40.65 -552.04 );
    allowFreeStandingZoneFaces true;
    curvature       0.9925;
    maxLoadUnbalance 0.01;
    resolveFeatureAngle 30.0;
    refinementSurfaces
        cavity
            level           (2 2);
            regions
    refinementRegions
snapControls
    nSmoothPatch    3;
    tolerance       4.0;
    smoothMesh      true;
    nSolveIter      30;
    nRelaxIter      5;
meshCheckControls
    pointsInsideMesh
    pointsOutsideMesh
addLayersControls
    relativeSizes   true;
    nSurfaceLayers  0;
    expansionRatio  1.2;
    finalLayerThickness 0.5;
    minThickness    0.1;
    nGrow           1;
    featureAngle    90;
    nRelaxIter      5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals  3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 130;
    nBufferCellsNoExtrude 0;
    nLayerIter      50;
    layers
meshQualityControls
    maxNonOrtho     65;
    maxBoundarySkewness 20;
    maxInternalSkewness 20;
    maxConcave      80;
    minFlatness     0.5;
    minVol          1e-13;
    minArea         -1;
    minTwist        0.05;
    minDeterminant  0.001;
    minFaceWeight   0.02;
    minVolRatio     0.01;
    minTriangleTwist 0.05;
    nSmoothScale    4;
    errorReduction  0.75;
Old   November 10, 2010, 09:54
Hi Samuele,
how did you come up with these points?
I just checked (like you probalby did as well) the motorBike tutorial
and the user documentation and they are not mentioned there.
So why would you introduce these to parameters and who came
up with that idea?
Unfortunately my sHMD is on a different computer so I can not show you my file but the beginning looks like this (note I skiped the FoamFile part):
snap  true;
addLayers   true;
geometry
and so on and so on....
I read through your code further and found some other parameters I'm not familiar with.
So it would be really interesting where you got the file from.
regards
Colin
Old   November 10, 2010, 14:14
Samuele Z
Dear Colin,
to be true, I got these files (sHMD and bMD) from a person who works daily with OF and who shared his samples with me.
I'll ask him news about those zones and then I'll post them here, if he agrees.
Ok??
Thanks again,
Samuele.
Old   November 11, 2010, 05:47
Thats a good idea, because it would be also interesting for me to know what these parameters are for.
looking forward to your post
regards
Old   November 11, 2010, 09:55
Samuele Z
I do not have good news.
The author of those files just told me that he used those sections with old (and not always released) versions of snappy.
Also, he told me that I can ignore them.
I am sorry.
Samuele
Old   December 10, 2010, 06:34
Nico T
deniggo is on a distinguished road
After running snappyHexMesh with satisfactory results the boundary condition in the 0.002/polyMesh folder is extented by one more entry:
name_solid
type wall;
nFaces 20512;
startFace 98394;
Obviosly, the case does not work anymore, when I copy the content of the new polyMesh folder to constant/polyMesh to replace the old files generated by blockMesh. A boundary error occurs.
Did I something wrong in the snappyHexMeshDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
snap            true;
addLayers       true;
geometry
    stlfileascii.stl
        name snaptest;
   /* refinementBox
        type searchableBox;
        min (-0.3 -0.1 -0.1);
        max ( 6.2  0.2 0.1);
    maxLocalCells 1000000;
    maxGlobalCells 2000000;
    minRefinementCells 10;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 2;
    features
        //    file "someLine.eMesh";
        //    level 2;
    refinementSurfaces
        snaptest
            level (1 2);
    resolveFeatureAngle 30;
    refinementRegions
       /* snaptest
            mode inside;
            levels ((0 4));
    locationInMesh (10 0.5 0.0);
snapControls
    nSmoothPatch 3;
    tolerance 4.0;
    nSolveIter 30;
    nRelaxIter 5;
addLayersControls
    relativeSizes true;
    layers
            nSurfaceLayers 1;
    expansionRatio 1.0;
    finalLayerThickness 0.3;
    minThickness 0.1;
    nGrow 1;
    featureAngle 30;
    nRelaxIter 3;
    nSmoothNormals 3;
    nLayerIter 50;
meshQualityControls
    maxNonOrtho 65;
    maxInternalSkewness 4;
    maxConcave 80;
    minFlatness 0.5;
    minVol 1e-13;
    minArea -1;
    minTwist 0.02;
    minFaceWeight 0.02;
    minVolRatio 0.01;
    minTriangleTwist -1;
    nSmoothScale 4;
debug 0;
mergeTolerance 1E-6;
deniggo is offline   Reply With Quote
Old   December 10, 2010, 06:58
Hi Deniggo,
well actually this is nothing unusual what you are describing.
The normal procedure is to create a background mesh with blockMesh and then with sHM you are introducing a solid where the flow of whatever goes around.
This solid has to be named and defined as well which is done automatically
by sHM in the boundary file.
You now have to specify this new patch also in the other boundary files
(U p k omega alpha1 or others depending on what kind of solver you use)
So there is nothing special about this.
What maybe can make things more easy for you is using the command
snappyHexMesh -overwrite
when creating the new mesh. This will suppres writing the new mesh in different time folders and it is immediatelly stored in the constant folder where the rest of your mesh is as well.
I hope I captchured your problem well if not let me know.
regards Colin
Old   December 10, 2010, 08:25
Nico T
Hi Colin,
thanks for your help.
I think, I have to reverse the stl-geometry and change the bounding box extent, because in my case the "whatever" is not flowing around the stl, it should flow inside. Now I understand, why all BC defined in blockMesh become 0 after running sHM- because they have been clipped.
Nico
Old   December 25, 2010, 04:06
Nico T
Hello sHM-profis,
after using sHM, the mesh contains some pentagonal cells (see attachment). How can I preserve the quadrangular cells, created by blockMesh? I want to use the obtained data for further calculations and need a geometrie with more or less equal intervals of cells/points.
I played a bit with several parameter in sHM but with no success (e.g. refinementSurfaces, maxNonOrtho). Which one I have to change?
Thanks for your help,
Nico
Old   January 5, 2011, 05:03
Nico T
When I change the maxNonOrtho to 10 instead of 80 only quadrangular elements are generated (see pic), but how can I avoid these sharp edges?
Can anyone help?
Thanks,
Nico
Thread Tools
Trackbacks are On
SnappyHexMesh with local refinement of ONE STLfile wolle1982 OpenFOAM Mesh Utilities 16 August 23, 2013 12:12
SnappyHexMeshDict fabrizio OpenFOAM Mesh Utilities 25 October 14, 2011 07:00
Any have a refined snappyHexMeshDict for the motorbike case? stark22 OpenFOAM Native Meshers: snappyHexMesh and Others 0 February 1, 2010 17:42
SnappyHexMeshDict setup Problem jakoff OpenFOAM Mesh Utilities 7 June 29, 2009 09:26
Geometry Generation In SnappyHexMeshDict henrik OpenFOAM Mesh Utilities 1 January 21, 2009 06:39
