[snappyHexMesh] Add Layers in snappyHexMesh
Like Tree9Likes
Old   September 14, 2016, 04:15
dupeng is on a distinguished road
Hello Sung Taek Park,
Thanks for your reply. I sent you a email but it was rejected by the server, so I will just post it here. I will try as you suggested and see if it works.
There is a quite great paper in ‘Ocean Engineering' called 'Dynamic overset grids in OpenFOAM with application to KCS self-propulsion and maneuvering' from Shanghai Jiao Tong University. They use snappyHexMesh and generate quite good boundary layer mesh for the hull (Fig.16 in this paper). For the propeller, it seems that they didn't use boundary layer mesh, but local refinement instead. I don't know if that's accurate enough because I am still focusing on the hull now. But that might be a hint for you. And this is the link for their simulations on Youtube:
https://www.youtube.com/channel/UC_l...NR9kosn8N-u4kA
They look amazing. Hope this can help you a little and Thank you again.
Best regards,
Peng DU
Tel: 0033 (0) 667084094
Email: pp1565156@126.com
Sorbonne universités, Université de technologie de Compiègne,
Laboratoire Roberval, UMR-CNRS 7337
Centre de Recherche Royallieu
CS 60319 - 60205 COMPIEGNE CEDEX FRANCE
Michael_Pacherres likes this.
dupeng is offline   Reply With Quote
Old   March 8, 2018, 08:18
Alejandro
ancolli is on a distinguished road
Any of you has solved the problem of generating boundary layers (y+<1) in complex geometries? I am facing the same problem with Salome and blockMesh
ancolli is offline   Reply With Quote
Old   November 23, 2019, 13:21
rucky96 is on a distinguished road
Is there anyone who can tell me what is the correct number of layers for a surface? Is there a rule based on experience?
rucky96 is offline   Reply With Quote
Old   March 22, 2020, 10:45
Gang Wang
Gang Wang is on a distinguished road
Best regards,
Peng DU
Hi Peng!
Have you solved the coupling between engrid and snappyHexMesh, as Dr. Sung Taek Park suggested? Through cyclicAMI. It was also my issue.
Best regards,
Gang
Gang Wang is offline   Reply With Quote
Old   May 14, 2020, 12:29
David Smith
minh khang is on a distinguished road
It works for me.
minh khang is offline   Reply With Quote
[snappyHexMesh] Snappy add layers failed mqsim OpenFOAM Meshing & Mesh Conversion 1 January 24, 2021 15:02
[snappyHexMesh] snappyHexMesh fails adding layers biscarri OpenFOAM Meshing & Mesh Conversion 13 March 21, 2020 12:40
[snappyHexMesh] snappyHexMesh not adding layers to a solid jet_engine OpenFOAM Meshing & Mesh Conversion 0 June 3, 2016 08:25
[snappyHexMesh] snappyHexMesh : Layers on patches Nucleophobe OpenFOAM Meshing & Mesh Conversion 0 October 11, 2012 17:34
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
