[Other] cgnsToFoam problems with "QUAD_4" cells
Old   March 8, 2011, 09:29
Default cgnsToFoam problems with "QUAD_4" cells
sirLentschi
lentschi is on a distinguished road
Hello everyone,
I performed cgnsToFoam but got some warnings:
| \\ / F ield | OpenFOAM Extend Project: Open source CFD |
| \\ / O peration | Version: 1.6-ext |
| \\ / A nd | Web: www.extend-project.de |
| \\/ M anipulation | |
Create time
--> FOAM Warning : Cell type "QUAD_4" found in zone 0, section 20 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 0, section 21 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 0, section 22 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 1, section 117 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 1, section 118 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 1, section 119 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 1, section 120 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 2, section 1 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 2, section 2 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 2, section 3 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 281 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 282 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 283 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 284 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 285 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 286 has no OpenFOAM equivalence - skipping
--> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 287 has no OpenFOAM equivalence - skipping
--> FOAM Warning : The BC "DT to RU Side 1" is defined with a type BCTypeNull.
It will be mapped to Foam's wallFunction type
--> FOAM Warning : The BC "DT to RU Side 2" is defined with a type BCTypeNull.
--> FOAM Warning : The BC "RU to SVWG Side 1" is defined with a type BCTypeNull.
--> FOAM Warning : The BC "SVWG to SC Side 2" is defined with a type BCTypeNull.
--> FOAM Warning : The BC "NOSE_LOWER Side 1" is defined with a type BCTypeNull.
--> FOAM Warning : The BC "NOSE_LOWER Side 2" is defined with a type BCTypeNull.
--> FOAM Warning : The BC "NOSE_UPPER Side 1" is defined with a type BCTypeNull.
--> FOAM Warning : The BC "NOSE_UPPER Side 2" is defined with a type BCTypeNull.
--> FOAM Warning : The BC "RU to SVWG Side 2" is defined with a type BCTypeNull.
--> FOAM Warning : The BC "SVWG to SC Side 1" is defined with a type BCTypeNull.
Output of mesh and boundary conditions
Now,I want to show this "QUAD_4" cells in ParaView to localize them.
Does anyone know, how I can do that?Additionally I don't know, how I can allocate the information "zone 0, section 20" to specific points?
Thanks in advance.
Markus
lentschi is offline   Reply With Quote
Old   March 9, 2011, 04:49
sirLentschi
I got it!
The adfviewer visualises these '"QUAD_4"-Cells.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Problem with prism cells sidharath ANSYS Meshing & Geometry 0 September 1, 2015 07:09
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
