[snappyHexMesh] snappyHexMesh won't work - zeros everywhere!
Like Tree1Likes
  • 1 Post By sc298
Old   March 23, 2011, 15:16
Default snappyHexMesh won't work - zeros everywhere!
sc298 is on a distinguished road
As you can probably tell I'm rather new to OpenFoam.
I'm having some trouble with snappyHexMesh.
I think I have set the case up correctly but when I run it, it does not refine the mesh and produces lots of zeros.
The print out of the terminal is shown here:
psypherdelic@Japtop:~/Documents/Computational/Small$ snappyHexMesh -overwrite
|  \\    /   O peration     | Version:  1.7.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 1.7.x-131caa989cd3
Exec   : snappyHexMesh -overwrite
Date   : Mar 23 2011
Time   : 19:14:00
Host   : Japtop
PID    : 2560
Case   : /home/psypherdelic/Documents/Computational/Small
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 3
Read mesh in = 0.07 s
Overall mesh bounding box  : (-5 -4 -3) (20 4 5)
Relative tolerance         : 1e-06
Absolute matching distance : 2.74408e-05
Reading refinement surfaces.
Read refinement surfaces in = 22.38 s
Reading refinement shells.
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0 s
Determining initial surface intersections
Edge intersection testing:
    Number of edges             : 4224
    Number of edges to retest   : 4224
    Number of intersected edges : 0
Calculated surface intersections in = 44.92 s
Initial mesh : cells:1280  faces:4224  points:1701
Cells per refinement level:
    0	1280
Adding patches for surface regions
Patch	Region
small:
6	small_small
Added patches in = 0 s
Selecting decompositionMethod simple
Refinement phase
Found point (2.48781 1.00986 0.473258) in cell 404 on processor 0
Reading external feature lines.
Read feature lines in = 0.01 s
Surface refinement iteration 0
Marked for refinement due to surface intersection : 0 cells.
Marked for refinement due to curvature/regions    : 0 cells.
Determined cells to refine in = 0 s
Selected for refinement : 0 cells (out of 1280)
Stopping refining since too few cells selected.
Removing mesh beyond surface intersections
Found point (2.48781 1.00986 0.473258) in cell 404 in global region 0 out of 1 regions.
Keeping all cells in region 0 containing point (2.48781 1.00986 0.473258)
Selected for keeping : 1280 cells.
    Number of edges to retest   : 0
Shell refinement iteration 0
Marked for refinement due to refinement shells    : 0 cells.
Determined cells to refine in = 0.05 s
Selected for internal refinement : 0 cells (out of 1280)
Splitting mesh at surface intersections
Introducing baffles for 0 faces that are intersected by the surface.
Created baffles in = 0.04 s
After introducing baffles : cells:1280  faces:4224  points:1701
    0	1280
Introducing baffles to block off problem cells
markFacesOnProblemCells : marked 0 additional internal faces to be converted into baffles.
Analyzed problem cells in = 0.02 s
Introducing baffles to delete problem cells.
Created baffles in = 0.03 s
    0	1280
Remove unreachable sections of mesh
Split mesh in = 0.03 s
After subsetting : cells:1280  faces:4224  points:1701
    0	1280
Handling cells with snap problems
    0	1280
    0	1280
Split mesh in = 0.04 s
    0	1280
dupNonManifoldPoints : Found : 0 non-manifold points (out of 1701)
getDuplicateFaces : found 0 pairs of duplicate faces.
Detected unsplittable baffles : 0
Merge refined boundary faces
mergePatchFaces : Merging 0 sets of faces.
Removing 0 straight edge points.
Refined mesh : cells:1280  faces:4224  points:1701
    0	1280
Writing mesh to time 3
Written mesh in = 0.21 s.
Mesh refined in = 0.53 s.
Morphing phase
Constructing mesh displacer ...
Using mesh parameters
    maxNonOrtho     65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave      80;
    minFlatness     0.5;
    minVol          1e-13;
    minArea         -1;
    minTwist        0.02;
    minDeterminant  0.001;
    minFaceWeight   0.02;
    minVolRatio     0.01;
    minTriangleTwist -1;
    nSmoothScale    4;
    errorReduction  0.75;
Checking initial mesh ...
Checking faces in error :
    non-orthogonality >  65 degrees                        : 0
    faces with face pyramid volume < 1e-13                 : 0
    faces with concavity >  80 degrees                     : 0
    faces with skewness >   4 (internal) or  20 (boundary) : 0
    faces with interpolation weights (0..1)  <  0.02       : 0
    faces with volume ratio of neighbour cells <  0.01     : 0
    faces with face twist <  0.02                          : 0
    faces on cells with determinant < 0.001                : 0
Detected 0 illegal faces (concave, zero area or negative cell pyramid volume)
Checked initial mesh in = 0.05 s
Smoothing patch points ...
Smoothing iteration 0
Found 0 non-mainfold point(s).
Scaling iteration 0
Moving mesh using diplacement scaling : min:1  max:1
Successfully moved mesh
Smoothing iteration 1
Scaling iteration 0
Smoothing iteration 2
Scaling iteration 0
Patch points smoothed in = 0.23 s
Calculating patchDisplacement as distance to nearest surface point ...
Calculated surface displacement in = 0 s
Moving mesh ...
Iteration 0
Moved mesh in = 0.08 s
Repatching faces according to nearest surface ...
Repatched 0 faces in = 0 s
    Number of edges to retest   : 2532
Snapped mesh : cells:1280  faces:4224  points:1701
    0	1280
Written mesh in = 0.16 s.
Mesh snapped in = 0.52 s.
Shrinking and layer addition phase
    maxNonOrtho     65;
    maxConcave      80;
    minFlatness     0.5;
    minVol          1e-13;
    minArea         -1;
    minTwist        0.02;
    minFaceWeight   0.02;
    minVolRatio     0.01;
    nSmoothScale    4;
Merging all faces of a cell
    - which are on the same patch
    - which make an angle < 30 degrees
      (cos:0.866025)
    - as long as the resulting face doesn't become concave by more than 90 degrees
      (0=straight, 180=fully concave)
No faces merged ...
Merging all points on surface that
- are used by only two boundary faces and
- make an angle with a cosine of more than 0.866025.
No straight edges simplified and no points removed ...
No layers to generate ...
Layer mesh : cells:1280  faces:4224  points:1701
    0	1280
Written mesh in = 0.14 s.
Layers added in = 0.14 s.
Finished meshing in = 68.56 s.
End
Any help would be very much appreciated as I have a project due in tomorrow and have been trying to get this to work for the last few days.
Many thanks
Sean
sc298 is offline   Reply With Quote
Old   March 23, 2011, 15:45
I think the problem could be my .stl file.
After running surfacecheck on the file a number of illegal triangles have been highlighted.
The output says:
--> FOAM Warning :
    From function validTri(const triSurface&, const label)
    in file surfaceCheck.C at line 95
    triangle 4003 vertices ((358781 358783 358785) 0) has the same vertices as triangle 1156530 vertices ((358785 358783 358781) 0) coords:3((485.578 56.0774 4250.1) (485.586 56.0746 4250.1) (485.592 56.0727 4250.1))
Surface has 1 illegal triangles.
Dumping conflicting face labels to "illegalFaces"
Paste this into the input for surfaceSubset
and
Surface is not closed since not all edges connected to two faces:
    connected to one face : 258
    connected to >2 faces : 1
Conflicting face labels:262
Dumping conflicting face labels to "problemFaces"
so...
I used the command:
surfaceSubset illegalFaces small.stl small2.stl
but this returned the error:
--> FOAM FATAL IO ERROR:
keyword localPoints is undefined in dictionary "illegalFaces"
file: illegalFaces
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 395.
Help!! :/
Old   March 27, 2011, 22:11
I am still needing help, thank you.
xoitx likes this.
Problem With using snappyhexmesh and getting simplefoam to work. Ivanj56 OpenFOAM Running, Solving & CFD 0 March 22, 2016 07:20
[snappyHexMesh] snappyHexMesh runs endless - I need general advise TeresaT OpenFOAM Meshing & Mesh Conversion 5 November 17, 2015 03:50
potentialFoam & simpleFoam crashes after snappyhexmesh [parallel execution] pilot320 OpenFOAM Running, Solving & CFD 10 November 12, 2015 17:56
First order in fvSchemes does not seem to work gerritgroot OpenFOAM Running, Solving & CFD 0 September 30, 2015 21:06
[snappyHexMesh] Error in SnappyHexMesh gooya_kabir OpenFOAM Meshing & Mesh Conversion 2 October 23, 2013 05:41
