-   OpenFOAM Native Meshers: snappyHexMesh and Others (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/)
-   -   Boundary layer in a pipe (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/92477-boundary-layer-pipe.html)
Clementhuon September 15, 2011 08:02
1 Attachment(s)
Hi OpenFOAMer,
I'm actually trying to mesh a cabin for a HVAC problem with the SHM. But after a lot of attempts I don't succed in creating my boundary layer in the entire pipe system. You will find enclosed a cross section of the pipe and a copy of my SHMdict file. You will see that when the curvature of my pipe increase, the BL desappear.
If somebody get an idea .... I allready read a lot of topic on the subject but found any explanation.
Thanks
Clement
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  1.7.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
|    \\/     M anipulation  |                                                 |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh 1;
snap            1;
addLayers       1;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
inlet.stl{
type triSurfaceMesh;
name inlet;}
outlet.stl{
name outlet;}
pipe.stl{
name pipe;}
inlay.stl{
name inlay;}
cabin-roof.stl{
name cabin-roof;}
cabin-side.stl{
name cabin-side;}
cabin-front.stl{
name cabin-front;}
cabin-floor.stl{
name cabin-floor;}
cabin-back.stl{
name cabin-back;}
refine-roof.stl{
name refine-roof;}
refine-panel-top.stl{
name refine-panel-top;}
panel.stl{
name panel;}
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
maxLocalCells 200000000;
// Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
maxGlobalCells 200000000;
// The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
minRefinementCells 2000;
// Allow a certain level of imbalance during refining
    // (since balancing is quite expensive)
    // Expressed as fraction of perfect balance (= overall number of cells /
    // nProcs). 0=balance always.
   // maxLoadUnbalance 0.1;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
nCellsBetweenLevels 5;
// Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
features
file "inlet.eMesh";
level 3;
file "outlet.eMesh";
level 3;
file "pipe.eMesh";
level 3;
file "inlay.eMesh";
level 3;
file "cabin-roof.eMesh";
level 3;
file "cabin-side.eMesh";
level 3;
file "cabin-front.eMesh";
level 3;
file "cabin-floor.eMesh";
level 3;
file "cabin-back.eMesh";
level 3;
file "refine-roof.eMesh";
level 3;
file "refine-panel-top.eMesh";
level 3;
file "panel.eMesh";
level 3;
// Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
inlet{
// Surface-wise min and max refinement level
level (5 5);}
outlet{
level (1 1);}
pipe{
level (5 5);}
inlay{
level (6 6);}
cabin-roof{
level (1 1);}
cabin-side{
level (1 1);}
cabin-front{
level (1 1);}
cabin-floor{
level (1 1);}
cabin-back{
level (1 1);}
refine-roof{
level (6 6);}
refine-panel-top{
level (6 6);}
panel{
level (1 1);}
// Resolve sharp angles
resolveFeatureAngle 10;
// Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
refinementRegions
// Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
locationInMesh (-1864.72 574.182 2774.74);
// Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
    //  to surface
nSmoothPatch 5;
//- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
tolerance 1.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 300;
//- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
nRelaxIter 15;
//- Highly experimental and wip: number of feature edge snapping
    //  iterations. Leave out altogether to disable.
nFeatureSnapIter 20;
// Settings for the layer addition.
addLayersControls
// Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
inlet_inlet{
nSurfaceLayers 2;};
pipe_pipe{
nSurfaceLayers 2;};
inlay_inlay{
nSurfaceLayers 2;};
refine-roof_refine-roof{
nSurfaceLayers 2;};
refine-panel-top_refine-panel-top{
nSurfaceLayers 2;};
// Expansion factor for layer mesh
expansionRatio 1.2;
//- Wanted thickness of final added cell layer. If multiple layers
    //  is the thickness of the layer furthest away from the wall.
    //  See relativeSizes parameter.
finalLayerThickness 0.8;
//- Minimum thickness of cell layer. If for any reasn layer
    //  cannot be above minThickness do not add layer.
    //  Relative to undistorted size of cell outside layer.
minThickness 0.05;
//- If points get not extruded do nGrow layers of connected faces that are
    //  also not grown. This helps convergence of the layer addition process
    //  close to features.
nGrow 0;
// Advanced settings
    //- When not to extrude surface. 0 is flat surface, 90 is when two faces
    //  make straight angle.
featureAngle 30;
nRelaxIter 20;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 20;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 20;
// Smooth layer thickness over surface patches
nSmoothThickness 10;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.1;
// Reduce layer growth where ratio thickness to medial
    // distance is large
maxThicknessToMedialRatio 0.05;
// Angle used to pick up medial axis points
minMedianAxisAngle 60;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations
nLayerIter 120;
nRelaxedIter 60;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 65;
//- Max skewness allowed. Set to <0 to disable.
maxBoundarySkewness 20;
maxInternalSkewness 4;
//- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
maxConcave 80;
//- Minimum projected area v.s. actual area. Set to -1 to disable.
minFlatness 0.5;
//- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
minVol 1e-06;
//- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre. This has to be a positive number for tracking
    //  to work. Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
minTetQuality 1e-9;
//- Minimum face area. Set to <0 to disable.
minArea 0.0001;
//- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //- and face centre triangles normal
minTwist 0.02;
//- minimum normalised cell determinant
    //- 1 = hex, <= 0 = folded or flattened illegal cell
minDeterminant 0.001;
//- minFaceWeight (0 -> 0.5)
minFaceWeight 0.02;
//- minVolRatio (0 -> 1)
minVolRatio 0.01;
//must be >0 for Fluent compatibility
minTriangleTwist -1;
// Advanced
    //- Number of error distribution iterations
nSmoothScale 4;
//- amount to scale back displacement at error points
errorReduction 0.75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
[IMG]file:///tmp/moz-screenshot.png[/IMG]
Clementhuon September 22, 2011 05:38
No idea ????
I tried a lot of combination for the parameters and didn't find any solution. Could someone help me ? If you don't have enough information I can give further description of my problem ........
Thanks
Clement
danvica March 11, 2012 10:53
Hi, I've got the same problem. Have you find a solution ?
Daniele
danvica March 11, 2012 12:51
Looking other threads it seems to be a naming problem, but I already tried several changes in the addLayersControls / layers setup.
Here is my SHMDict:
castellatedMesh true;
snap            true;
addLayers      true;
geometry
    tubo.stl
        name tubo;
        regions
            tubo
                name tubo;
    inlet.stl
        name inlet;
        regions
            inlet
                name inlet;
    outlet.stl
        name outlet;
        regions
            outlet
                name outlet;
    //refinementBox
    //    type searchableBox;
    //    min (-0.01 -0.01 -0.31);
    //    max ( 0.01  0.01 0.01);
    maxLocalCells 100000;
    maxGlobalCells 2000000;
    minRefinementCells 10;
    maxLoadUnbalance 0.10;
    // refinement.
    features
        //    file "someLine.eMesh";
        //    level 2;
    refinementSurfaces
        tubo
            //level (5 6);
            level (2 3);
        inlet
            //level (5 6);
            level (2 3);
        outlet
            //level (5 6);
            level (2 3);
    resolveFeatureAngle 30;
    // three modes
    refinementRegions
        //tubo
        //    mode inside;
        //    levels ((1E15 2));
    // Mesh selection
    locationInMesh (0 0 -0.2);
snapControls
    //  to surface
    nSmoothPatch 3;
    tolerance 4.0;
    //nSolveIter 0;
    nSolveIter 30;
    nRelaxIter 5;
    //  Do not use here since mesh resolution too low and baffles present
    //nFeatureSnapIter 10;
addLayersControls
    relativeSizes true;
    layers
        tubo
            nSurfaceLayers 5;
        inlet
            nSurfaceLayers 5;
        outlet
            nSurfaceLayers 5;
    expansionRatio 1.0;
    //  is the
    //  thickness of the layer furthest away from the wall.
    //finalLayerThickness 0.3;
    finalLayerThickness 0.1;
    //- Minimum thickness of cell layer. If for any reason layer
    minThickness 0.1;
    //minThickness 0.0005;
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 1;
    featureAngle 30;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedianAxisAngle 90;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
// where to undo.
meshQualityControls
    maxNonOrtho 65;
    maxConcave 80;
    minVol 1e-13;
    //  disable.
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality 1e-30;
    minArea -1;
    minTwist 0.02;
    minFaceWeight 0.02;
    minVolRatio 0.01;
    // Advanced
    nSmoothScale 4;
// Advanced
debug 0;
mergeTolerance 1e-6;
Thanks for any help.
Daniele
danvica March 12, 2012 03:08
1 Attachment(s)
After some trial I've got a SHMDict that works creating layers.
Note: maybe it was just me that checked the mesh in Parafoam looking just at inlet surface (without cutting the pipe#. I was expecting a layering on this surface too.
The problem now is on the terminal surfaces. The layers are mergin all togheter in a single cell #see picture). I red that featureAngle can modify this behavior. I'll try it but... Any hint ?
danvica March 12, 2012 09:05
2 Attachment(s)
Using that mesh give me a problem in solving an Interfoam laminar case.
I don't know whether continue this thread here or move into the solvers forum.
Anyway, as you can see in the pictures, the irregular mesh causes some high pressure spots. The simulation is still going, no crash at the moment.
Any hint how to improve the mesh ?
Daniele
danvica March 12, 2012 13:41
I hopefully found a solution at http://www.cfd-online.com/Forums/ope...tlet-pipe.html
