[snappyHexMesh] snappy hex mesh error
Old   December 31, 2011, 07:35
Default snappy hex mesh error
kd55 is on a distinguished road
Hi there, I am trying to get to grips with sHM but am finding it hard to follow some of the tutorials online and in the user guide. I have an STL file of a cylinder which will be used for preliminary tests. Would it be possible for someone to have a quick look at the error I am getting when I run snappyHexMesh and point me in the right drection:
FOAM Warning :
From function entry::getKeyword(keyType&, Istream&)
in file db/dictionary/entry/entryIO.C at line 78
Reading /home/kd55/OpenFOAM/kd55-1.6/run/tutorials/incompressible/pisoFoam/ras/STLCylinder2-copy/system/snappyHexMeshDict
found on line 86 the punctuation token '{'
expected either } or EOF
keyword meshQualityControls is undefined in dictionary "/home/kd55/OpenFOAM/kd55-1.6/run/tutorials/incompressible/pisoFoam/ras/STLCylinder2-copy/system/snappyHexMeshDict"
file: /home/kd55/OpenFOAM/kd55-1.6/run/tutorials/incompressible/pisoFoam/ras/STLCylinder2-copy/system/snappyHexMeshDict from line 24 to line 87.
From function dictionary::subDict(const word& keyword)
in file db/dictionary/dictionary.C at line 467.
FOAM exiting
relevant files should be attatched bar the STL
Kind Regards,
Kit
kd55 is offline   Reply With Quote
Old   December 31, 2011, 12:23
Retired Super Moderator
Bruno Santos
Greetings Kit,
It looks to me like you aren't using a proper text editor. My favourite one is Kate, although it requires KDE to be installed, which can mean that you would need to download and install an additional 200-300 MB of packages.
Either way, I suggest that you take more care with where the brackets "{" and "}" are placed, because the following fields have the "}" ones in the wrong place:
  • addLayersControls - has a closing bracket too soon.
  • meshQualityControls - didn't even have a closing bracket.
Another thing that I advise you is to define in your text editor to use spaces instead of tabs.
Another advice is to always have the original "snappyHexMeshDict" open in another window, so you can consult it and compare it with your current version.
edit: by what I've seen from your previous posts, you might be running on Windows. So you might be interested in this: http://code.google.com/p/bluecfd-sin...epad2_manually
Best regards and good luck!
Bruno
Old   January 5, 2012, 09:01
thanks Bruno, sHM now seems to be working.
Thanks again,
Kit
Old   January 6, 2012, 11:08
Aqua
aqua is on a distinguished road
Thanks again,
Kit
Dear Kit,
I have the same problem as yours, could you please tell me how you got your case working?
Thank you so much!
Aqua
aqua is offline   Reply With Quote
Old   January 7, 2012, 10:01
Hi Aqua,
I'm not so sure I have got it working now, as I am using snappy in the pisofoam solver which I can't run at the moment as it has a bug which is caused by the R file in the 0 directory. However, I do have a few pointers on where you might be going wrong as I have spent quite a lot of time on this now:
- if you are using paraview (not parafoam), i would use foamToVTK to transfer the data files
- copy the snappyHexMesh dict from the motorbike tutorial and make sure you are carefull when making changes to it, i.e. be carefull with th {,(,),}. change little bits at a time and make sure you know what you are changing, there is plenty of info on here. There are also some online tutorials:
http://www.hydroniumion.de/general/s...mesh-tutorial/
http://www.hydroniumion.de/studium/s...torial-part-2/
Regards,
Kit
Old   January 9, 2012, 05:53
Aqua
Hi Aqua,
Regards,
Kit
Hello Kit,
Thank you so much for your help! I am reading the turorials and hopefully will find some solution!
Thank you so much and wish you good luck in your research!
Aqua
Old   February 17, 2012, 03:07
Elise
Elise is on a distinguished road
I get the same error; keyword meshQualityControls is undefined in dictionary snappyHexDict. I looked at the right places for the brackets but I can't figure it out?
I'm trying to make a mesh inside the scour stl file instead of outside the region.
Elise is offline   Reply With Quote
Old   February 17, 2012, 04:42
Elise
I had the wrong internal co-ordinates and also had an old mesh in the polymesh folder.
However, I want to refine my grid at the walls inside the stl file, how can I do this?
And further I want to make a patch at the left small tube to let water in and a patch on the left largest circle part to let water out again. The rest I want as a patch to specify a B.C. on it (wall, no velocity, no flux). How can I do this?
Old   February 17, 2012, 16:20
Aqua
I think you need to creat different parts in stl file first according to how many patches you want to creat.
Aqua
Old   February 18, 2012, 07:02
Bruno Santos
Greetings to all!
@Elise: You can with createPatch. You can find several examples by running:
find $WM_PROJECT_DIR -name createPatchDict
If your geometry has good features (i.e., not trying to create a small patch in a flat surface), you can use autoPatch.
Best regards,
Bruno
Old   February 20, 2012, 06:55
Aqua
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Hello Bruno,
I wonder, If my geometry is a car with only one part named "car", in a stl file.
After snappyHexMesh, in the boundary file there is only the patch named "car". Then,
Now I want to create different parts for the car such as "car_frontwindow", "car_backwindow", "car_leftsidewindow" etc.
Is it possible to do that in OF?
Thank you so much!
Aqua
Old   February 20, 2012, 07:41
Elise
I loaded in the different stl files instead of one stl file, now I have the different patches.
Next time I will use autopatch, easier to use I think.
Old   February 20, 2012, 08:56
Bruno Santos
Originally Posted by aqua View Post
Hello Bruno,
It should be possible. Like I wrote on the other post, search for the examples that already exist
The downside of autoPatch (besides the previously mentioned issue) is that you then have to manually rename every patch on "*/polyMesh/boundary". If the geometry doesn't change, or at least not the order of the patches being found, you can use a "changeDictionaryDict" for renaming patches with a pre-done renaming pattern
Best regards,
Bruno
Old   July 16, 2018, 21:07
Default snappyHexMeshDict IOstream issue
  #14
Ewan
EFRENCH is on a distinguished road
I am trying to run snappyHexMesh having only modified a couple of things in the control Dict to suit my patches but the following error keeps cropping up "keyword meshQualityControls is indefined in dictionary "IOstream"". The 'meshQualityControls' has also been 'castellatedMeshControls' depending on which parts I comment out.
I am working in Docker if that has any effect but I think it is probably me just missing some punctuation somewhere! Please could someone help?
(I've had to rename the file to a .txt but if you change it back to .mh it should open!)
EFRENCH is offline   Reply With Quote
Old   July 17, 2018, 02:13
Unhappy understanding SHM
  #15
ABDUR REHMAN
MANI567 is on a distinguished road
hello everyone. i am new to openFoam and i have been working on it for 3 weeks. i failed in finding any reference videos that tell me how i can use shm on different geometries and how to create thir shm files.
can anyone help me in this regard !
thank you
MANI567
MANI567 is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
