[blockMesh] Wedge geometry with two blocks
Like Tree2Likes
  • 1 Post By sega
  • 1 Post By sega
Old   June 18, 2008, 08:48
Default Wedge geometry with two blocks
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
For my next problem, I need a axisymmetric geometry like this:
I have done some wedge-geometry before but this is special to me.
I need two different boundary-conditions at the bottom: Inflow for the red area, wall for the blue area.
So, I tried to blockMesh the geometry using two blocks.
blockMeshDict
But this is not working.
How can I manage this problem?
Do you have any ideas?
skynet4ever likes this.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   June 18, 2008, 09:59
Default I think I didn't use the conve
sega's Avatar
Sebastian Gatzka
I think I didn't use the convention that the two wedge-patches should straddle the x-y-plane ...
On first impression the mesh looks good.
blockMeshDict
Old   January 7, 2012, 07:11
skynet4ever is on a distinguished road
Hi sega (or anyone),
I have a similar Problem. It would be very nice if you could help!!! I modified the blockMesh file above to achieve the following Situation:
I have a axisymmetric geometry but with an hole around the center. It is just like your block0 is missing. On the new emerging boundary of the second block1 I have a inflow condition. Do you think this is possible with openfoam without sacrificing the symmetry ???
This question is connected to my general problem posted in this Thread:
http://www.cfd-online.com/Forums/ope...tml#post337855
Thank you for helping!
Philipp
skynet4ever is offline   Reply With Quote
Old   January 7, 2012, 09:04
Default solved
Hi @all,
I think I solved the Problem concerning the mesh. I attached the corresponding file if somebody should have a similar problem. I thought I had already tried a similar solution but it didn't work
p.s.: the other problem (concerning the formulation of the equations in the grid) is still open for discussion. please help.Thx
[ICEM] Blocking an elbow (block not conforming to geometry) llrr12 ANSYS Meshing & Geometry 0 January 22, 2015 22:06
Problem with building geometry - concentric cylinders Rhoddwen OpenFOAM Pre-Processing 9 December 17, 2014 10:02
Problem with geometry - concentric cylinders Rhoddwen OpenFOAM Running, Solving & CFD 0 December 15, 2014 09:22
[blockMesh] "hex" blocks that give prism and tet wedge cells MaryBau OpenFOAM Meshing & Mesh Conversion 1 January 30, 2013 13:46
[ANSYS Meshing] Increasing number of blocks for parallel computing purposes Ivan ANSYS Meshing & Geometry 1 August 6, 2012 10:12
