[snappyHexMesh] Difference in number of cells between Paraview and Log files
Old   January 9, 2012, 06:21
Default Difference in number of cells between Paraview and Log files
Unnikrishnan Mohankumar
unnikrsn is on a distinguished road
Dear Foamers,
I have small problem with the number of cells in the log file and the Object Inspector in Paraview
In Log.File for SnappyHexMesh
Layer mesh : cells : 2,484,394
Object Inspector - Paraview
Number of Cells : 7,463,450
I assume that the Log file for SnappyHexMesh is correct..
but why is there a difference in cells in Paraview
Thanks
Unnikrishnan
unnikrsn is offline   Reply With Quote
Old   January 10, 2012, 04:11
norman1981's Avatar
Norman Del Puppo
norman1981 is on a distinguished road
Hi Unnikrishnan,
check if you have enabled the "Decompose polyhedra" checkbox in the Object Inspector panel (see the Properties tab).
Regards
Norman
norman1981 is offline   Reply With Quote
Old   January 10, 2012, 06:45
Thanks Norman,
But i am using Paraview 3.6.1. and my paraview doesn't show an option to enable "Decompose polyhedra" checkbox in the Object Inspector panel (Properties tab).
what version are you using.
Does it have something to do with DecomposePolyhedra
OpenFOAMReader for Paraview.
Thanks
Unnikrishnan
Old   January 10, 2012, 06:53
norman1981's Avatar
Norman Del Puppo
Yeah you're right, I might be wrong but this checkbox was included starting from Paraview 3.10. I am using Paraview 3.12.0-RC2. Download an up to date paraview version, then create an empty file (.foam extension) in your case directory (in example: touch case.foam). Run paraview and load that file, it should work fine :-)
Regards
Norman
Old   January 10, 2012, 07:38
Thanks Norman,
Thanks for the reply.
I am still using paraview 3.6.1...
I will be asking my university staff to update the Paraview to 3.12.
I was not able to update it on my own as regular user ( not Root User ).
I tried it with Cmake from Paraview build and install.. But it dint work...
http://paraview.org/Wiki/ParaView:Build_And_Install#Build_Your_Own_CMake
If you have some link for Regular user.. do share it...
Thanks & Regards
Unnikrishnan
Old   January 10, 2012, 07:46
norman1981's Avatar
Norman Del Puppo
Well, why don't you try a pre-compiled version? You can download the one you need here: http://www.paraview.org/paraview/res.../software.html .
Then unpack the package in your home. Run the package paraview executable. In this way you won't need your system admin anymore :-)
Norman
Old   January 10, 2012, 09:52
Hi Norman,
I have installed paraview 3.12 with the help of my Lab IT-Incharge...
With the Paraview3.12 the problem seems to be solved.
Now it display the correct results.
Thanks for the help...
Thanks & Regards
Unnikrishnan.
Keeping intermediate files OVS SU2 5 December 5, 2021 11:41
Difference between forceCoeffs function and Paraview force calculation alexey_sw OpenFOAM Post-Processing 2 June 9, 2021 04:05
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Shape optimization doesn't converge - Adjoint log file JPBLourenco SU2 Shape Design 0 December 11, 2017 08:41
[OpenFOAM] ParaView shows bad cells, checkMesh doesn't seem to notice. CoolHand ParaView 2 August 21, 2014 15:58
