[snappyHexMesh] snappyHexMesh, Multi-Regions & Boundary Layers
Like Tree5Likes
  • 3 Post By mabinty
  • 1 Post By mabinty
  • 1 Post By mabinty
Old   January 31, 2012, 08:45
Question snappyHexMesh, Multi-Regions & Boundary Layers
ThibaudB
ThibaudB is on a distinguished road
Hello OpenFOAMers,
in a previous thread, I was struggling with sHM and complex geometries, but this time, the case involves a much simpler geometry, in a quite standard configuration.
My problem consists in the simulation of heat transfer of a cylinder in a transverse flow. It involves the chtMultiRegionFoam solver, thus needing (in my case) a fluid and solid region.
I would like to use layers refinement in the fluid region at the interface between the fluid space and the solid cylinder, but either sHM generates the 2 regions without layers (only the normal leveled refinements) either it only generates the fluid region without solid region, but boundary layers at the wall where the solid region should be.
Is it so, that specifying layers in a multi-region sHM case will unfortunately not be possible because of incompatible interfaces between the solid region and the created refined layers?
Thanks in advance for any hints/help!
Regards,
Thibaud
ThibaudB is offline   Reply With Quote
Old   February 1, 2012, 05:28
Eugene de Villiers
eugene is on a distinguished road
As you observed it is not possible to have layers at fluid-solid interfaces when using standard snappyHexMesh.
eugene is offline   Reply With Quote
Old   April 19, 2012, 07:16
val46 is on a distinguished road
Hi Eugene,
Originally Posted by eugene View Post
... when using standard snappyHexMesh.
you mean there are versions of sHM that can handle layer generation in multi-region cases?
"When I meet God, I am going to ask him two questions: Why relativity? And why turbulence? I really believe he will have an answer for the first." Werner Heisenberg
val46 is offline   Reply With Quote
Old   October 1, 2013, 02:28
Robert Castilla
rcastilla is on a distinguished road
I am facing now the same problem. Is still no possible to add layers in a multiregion mesh?
Thanks
Robert
rcastilla is offline   Reply With Quote
Old   October 1, 2013, 16:50
Miro
miro2000 is on a distinguished road
Hello everyone,
you should check out propeller tutorial, IIRC mesh there consists of multiple regions with baffles in between.
There was a thread about that a few weeks back, i don't know if there was a solution.
However, if anyone figures out how to mesh multiple regions with snappy, i very much like to see how it works. I would do it myself, but unfortunately I just don't have the time right now.
miro2000 is offline   Reply With Quote
Old   October 30, 2013, 05:58
Aram Amouzandeh
mabinty is on a distinguished road
Dear all,
I modified the utility snappyHexMesh in order to accept the "-region <regionName>" option called snappyHexMeshMR by changing the lines 131 and 136/137 in snappyHexMeshMR.C (see attachment). Its not extensively tested. I just used it for layer insertion (castellatedMesh false; snap false; addLayers true; ) and so far it worked for me. Extract snappyHexMeshMR.gz in $WM_PROJECT_USER_DIR/applications directory and then do wclean and wmake. The utility then works as
snappyHexMeshMR -region <regionName>
As for the default case, it needs the respective .stl file in constant /<regionName>/triSurface/ as well as the snappyHexMeshDict in system/<regionName>/.
Hope you can make use of it. Any feedback is appreciated!!
Cheers,
Aram
mabinty is offline   Reply With Quote
Old   December 9, 2013, 03:06
Andrzej Prusiński
Prosiaczek is on a distinguished road
Hello Aram,
I am looking at your software (snappyHexMeshMR with option region), but it seams that it doesn't work in my case.
Starting form the installation of the attached snappyHexMeshMR:
I've used commands like you wrote and the files are placed like this:
OpenFOAM
|-user-2.2.2
--|-run
----|-my_case
------|-Make
------|-constant
--------|-region
------ |-system
-------- |-region
------ |-1
------ |-2
------ |-snappyHexMeshMR.C
------ |-snappyHexMeshMR.dep
In folder region (in constant and in system) are files needed by the software
when I'm doing first step which I mean doing simply snappyHexMesh for my *.stl file with castelledMesh and snapping everything goes fine. After that I use "snappyHexMeshMR -region region" and it end without doing anything - It seems like the snappyHexMeshMR couldn't find *.stl or eMesh or even previously made mesh (castelledMesh and snappy).
Maybe I've made some mistake with unpacking the software or I simply made huge mess in my folder so the software can't find files?
Last edited by Prosiaczek; December 9, 2013 at 03:08. Reason: quick reply erase <space> which mades the structure of folder illegible
Prosiaczek is offline   Reply With Quote
Old   December 9, 2013, 12:15
Aram Amouzandeh
hey!
it looks like you have no snappyHexMeshDict in your system/region/ folder but then I wonder why snappy did not output an error ... what is the output of "snappyHexMeshMR -region region" saying? however, there is no need to put the snappyHexMeshMR.C and snappyHexMeshMR.dep in any of your case folders!
cheers,
aram
Old   December 10, 2013, 02:14
Andrzej Prusiński
Hi Aram.
Thank you for fast replay. I do have the snappyHexMeshDict in my region folder inside the system folder with such a configuration:
- castelledMesh false
- snap false
- addLayers true
which is exact opposite to the snappyHexMeshDict located in the <my_case>/system.
This is an output created after usage of snappyHexMeshMR
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.2-9240f8b967db
Exec   : snappyHexMeshMR -region warstwa
Date   : Dec 10 2013
Time   : 08:09:04
Host   : "PC5EJ1"
PID    : 2738
Case   : /home/andrzej/OpenFOAM/andrzej-2.2.2/run/oplyw_bez_styku
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh warstwa for time = 0
Read mesh in = 0.03 s
Overall mesh bounding box  : (-4 -4 -4) (4 4 4)
Relative tolerance         : 1e-06
Absolute matching distance : 1.38564e-05
Reading refinement surfaces.
Read refinement surfaces in = 0.01 s
Reading refinement shells.
--> FOAM Warning :
    From function shellSurfaces::shellSurfaces(..)
    in file autoHexMesh/shellSurfaces/shellSurfaces.C at line 419
    Reading "/home/andrzej/OpenFOAM/andrzej-2.2.2/run/oplyw_bez_styku/system/warstwa/snappyHexMeshDict.castellatedMeshControls.refinementRegions" from line 146 to line 147
    Not all entries in refinementRegions dictionary were used. The following entries were not used :
2
levels
mode
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0 s
Reading features.
Refinement level according to distance to "test.eMesh" (0 points, 0 edges).
    level 2 for all cells within 0 meter.
Detected 0 featurePoints out of 0 on feature test.eMesh
--> FOAM Warning :
    From function treeBoundBox::treeBoundBox(const UList<point>&)
    in file meshes/treeBoundBox/treeBoundBox.C at line 136
    cannot find bounding box for zero-sized pointField, returning zero
Read features in = 0 s
Determining initial surface intersections
Edge intersection testing:
    Number of edges             : 25200
    Number of edges to retest   : 25200
    Number of intersected edges : 1032
Calculated surface intersections in = 0.03 s
Initial mesh : cells:8000  faces:25200  points:9261
Cells per refinement level:
    0    8000
Adding patches for surface regions
Patch    Type    Region
test:
1    wall    test_OpenSCAD_Model
Added patches in = 0 s
Selecting decompositionMethod none
Layer thickness specified as final layer and expansion ratio.
Shrinking and layer addition phase
Using mesh parameters
    maxNonOrtho     75;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave      80;
    minVol          1e-20;
    minTetQuality   1e-13;
    minArea         -1;
    minTwist        0.05;
    minDeterminant  0.001;
    minFaceWeight   0.005;
    minVolRatio     0.001;
    minTriangleTwist -1;
    nSmoothScale    4;
    errorReduction  0.75;
    relaxed
        maxNonOrtho     75;
Merging all faces of a cell
    - which are on the same patch
    - which make an angle < 1 degrees
      (cos:0.999848)
    - as long as the resulting face doesn't become concave by more than 90 degrees
      (0=straight, 180=fully concave)
Merging 0 sets of faces.
No faces merged ...
Merging all points on surface that
- are used by only two boundary faces and
- make an angle with a cosine of more than 0.999848.
No straight edges simplified and no points removed ...
No layers to generate ...
Layer mesh : cells:8000  faces:25200  points:9261
    0    8000
Writing mesh to time 1
Wrote mesh in = 0.01 s.
Layers added in = 0.01 s.
Finished meshing in = 0.08 s.
End
If I'm right the snappyHexMeshMR allow me to addLayers to the case where is used multi region (by meaning faceZone and cellZone).
Regards
Andrzej
Old   December 10, 2013, 10:26
Aram Amouzandeh
Hey Andrzej,
yes the tool was modified in order to add layers in a region to a specific patch of the respective region. It is important, that you refer to a none-zero patch which has an entry in the constant/<regionName>/polyMesh/boundary file, not to a patch which is only present in your surfache file (i.e. e.g. a .stl)!
You normaly split the mesh with splitMesh into single regions after snappyHexMesh created the face- and cellZone of your desired regions (for an example see the multiRegionHeater tutorial). Then, you can add layers only to the (non-zero) patches which splitMesh creates and writes into the constant/<regionName>/polyMesh/boundary file.
I forgot to ask last time: could you also post the dictionary you used with snappyHexMeshMR.
Cheers,
Aram
Prosiaczek likes this.
Old   December 11, 2013, 05:06
Andrzej Prusiński
Hi Aram,
Thanks to your suggestion I have started to looking for information: how to create a patch without the snappyHexMesh. But from what I found it seems that to create patch before the snappyHexMesh I need to use "createPatchDict" which is rather of a way to create simple patches (not designed for the complex geometry) ;/
My model for the test purpose consist just of the sphere and surroundings (box around mentioned sphere), where I need to apply layers for both Zones.
Either way I also tried to do the splitMesh (without having any other patches than those which are created by the snappyHexMesh), so I wrote such a command in terminal:
splitMesh test test_OpenSCAD_Model test_OpenSCAD_Model_slave
As u can see in attached snappyHexMeshDict test is the name for the stl file, test_OpenSCAD_Model - is a patch where the layer are extruded and the _slave is what snappyHexMesh create when i try to create the faceZona and cellZone.
If You could tell me:
a) whether my guess about createPatch function is good or not and should I follow this track?
b) if I correctly found needed names for the splitMesh?
btw. Here I enclose the snappyHexMeshDict which is located inside the region folder designed for my region:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      autoHexMeshDict;
// Which of the steps to run
snap            false;
addLayers       true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    sphereA
        type searchableSphere;
        centre (0 0 0);
        radius 3;
        name sphere;
    test.stl
        type triSurfaceMesh;
        name test;
// Settings for the castellatedMesh generation.
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 3000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 20000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 2;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 1;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
            file "test.eMesh";
            level 2;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
    sphere
        level (1 2);
            faceZone sphere;
            cellZone sphere;
            cellZoneInside outside;
    test
        level (1 2);
/*            faceZone test;
            cellZone test;
            cellZoneInside inside;
    resolveFeatureAngle 1;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
    mode inside;
    levels ((1E15 3));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    // This is an outside point locationInMesh (-0.033 -0.033 0.0033);
    locationInMesh (0 0 0); // Inside point
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 18;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 1.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 300;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 20;
    // Feature snapping
        //- Number of feature edge snapping iterations.
        //  Leave out altogether to disable.
        nFeatureSnapIter 20;
        //- Detect (geometric) features by sampling the surface
        implicitFeatureSnap false;
        //- Use castellatedMeshControls::features
        explicitFeatureSnap true;
        //- Detect features between multiple surfaces
        //  (only for explicitFeatureSnap, default = false)
        multiRegionFeatureSnap true;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
    bez_styku_OpenSCAD_Model_slave
            nSurfaceLayers 2;
    test_OpenSCAD_Model
            nSurfaceLayers 2;
    // Expansion factor for layer mesh
    expansionRatio 0.8;
    // Wanted thickness of final added cell layer. If multiple layers
    // is the thickness of the layer furthest away from the wall.
    // See relativeSizes parameter.
    finalLayerThickness 0.2;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 0.1;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    nGrow 1;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 1;
    // Maximum number of snapping relaxation iterations. Should stop
    nRelaxIter 5;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 3;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    minMedianAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
    // Max number of iterations after which relaxed meshQuality controls
    // get used. Up to nRelaxIter it uses the settings in meshQualityControls,
    // after nRelaxIter it uses the values in meshQualityControls::relaxed.
    nRelaxedIter 20;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 75;
    //- Max skewness allowed. Set to <0 to disable.
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 80;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol 1e-20;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre.  Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //- and face centre triangles normal
    minTwist 0.05;
    //- minimum normalised cell determinant
    //- 1 = hex, <= 0 = folded or flattened illegal cell
    //- minFaceWeight (0 -> 0.5)
    //- minVolRatio (0 -> 1)
    minVolRatio 0.001;
    //must be >0 for Fluent compatibility
    //- if >0 : preserve single cells with all points on the surface if the
    //  resulting volume after snapping (by approximation) is larger than
    //  minVolCollapseRatio times old volume (i.e. not collapsed to flat cell).
    //  If <0 : delete always.
    //minVolCollapseRatio 0.5;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- amount to scale back displacement at error points
    // Optional : some meshing phases allow usage of relaxed rules.
    // See e.g. addLayersControls::nRelaxedIter.
    relaxed
        maxNonOrtho 75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
Old   December 11, 2013, 09:18
Aram Amouzandeh
hey,
to your questions:
a) a possible idea but might not be necessary
b) sorry I was talking about the tool "splitMeshRegions", not "splitMesh" as I wrongly mentioned in my previous post. splitMeshRegions creats two separate regions with seperate meshes from e.g. cellZones and then creates patches at the interface of these regions.
So the procedure I d suggest you should follow is:
1.) mesh the two regions (box and sphere) and create faceZones/cellZones for each region with snappyHexMesh (see e.g. the tutorial mesh/snappyHexMesh/snappyMultiRegionHeater/).
2.) create two separate regions with "splitMeshRegions -cellZones" (for additional info see also http://www.cfd-online.com/Forums/ope...tml#post341623).
3.) add layers in your regions with "snappyHexMeshMR -region <regionName>". as you want to add layers at the interface of your box and sphere, look for the name of the interface patch in constant/<regionName>/polyMesh/boundary and use this patch name in your layers dictionary of the snappyHexMeshDict.
hope that helps!
cheers,
aram
Old   December 17, 2013, 06:59
Andrzej Prusiński
Hi Aram,
It seems that I am lost again and I am not sure where I have made a mistake. I am guessing that at the step with spliMeshRegions I am doing something wrong (I've read linked by you topic concer the usage of "setSet"), but trying to explain what is wrong would be probably way to difficult for both sides ;/ so i'll try to copy here my input, output and set of the commands which i used:
1. Here is my snappyHexMeshDict file:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
castellatedMesh true;
snap            true;
addLayers       false;
geometry
    box.stl
        name box;
    kula.stl
        name kula;
    maxLocalCells 30000;
    maxGlobalCells 200000;
    minRefinementCells 6;
    // refinement.
    nCellsBetweenLevels 5;
    features
            file "kula.eMesh";
            level 2;
            file "box.eMesh";
            level 2;
    refinementSurfaces
    kula
        level (3 4);
            faceZone kula;
            cellZone kula;
    box
        level (3 4);
            faceZone box;
            cellZone box;
    // three modes
    refinementRegions
    //mode inside;
    //levels ((1E15 3));
    // Mesh selection
    locationInMesh (-3.8 -3.8 -3.8); // Inside point
snapControls
    //  to surface
    nSmoothPatch 10;
    tolerance 1.0;
    nSolveIter 150;
    nRelaxIter 10;
    // Feature snapping
addLayersControls
    relativeSizes true;
    layers
    allBoundary
            nSurfaceLayers 3;
    expansionRatio 0.8;
    minThickness 0.1;
    nGrow 1;
    featureAngle 25;
    nRelaxIter 5;
    nSmoothNormals 3;
    // mesh.
    nLayerIter 50;
    nRelaxedIter 20;
// where to undo.
meshQualityControls
    maxNonOrtho 75;
    maxConcave 80;
    minVol 1e-20;
    //  disable.
    //      0 = flat tet
    //      1 = regular tet
    minArea -1;
    minTwist 0.05;
    minDeterminant 0.01;
    minVolRatio 0.001;
    // Advanced
    nSmoothScale 4;
    relaxed
        maxNonOrtho 75;
// Advanced
debug 0;
Just for information the kula.stl and box.stl are one and the same file, but to experiment faster I just used same file (consisting sphere geometry) with diffrent names and select for cellZones in case of kula - "inside" mode and for the box - "outside".
2. To run snappyHexMesh I have made my own "Allrun" file:
#!/bin/sh
rm -r constant/extendedFeatureEdgeMesh
rm constant/triSurface/*.eMesh
rm -r 1 2 3
blockMesh
surfaceFeatureExtract
decomposePar
mpirun -np 3 snappyHexMesh -parallel
reconstructParMesh -mergeTol 1e-6 -time 1
reconstructParMesh -mergeTol 1e-6 -time 2
rm -r processor*
3. As you suggest, I have used post from "wyldckat" and made my batch.setSet file:
cellSet isolation new zoneToCell kula
cellSet isolation add zoneToCell box
cellSet isolation subset
4. Than I just used those 2 commands:
setSet -batch batch.setSet
Result of this:
Exec   : setSet -batch batch.setSet
Date   : Dec 17 2013
Time   : 12:20:08
Host   : "PC5EJ1"
PID    : 4313
nProcs : 1
Create time
Create polyMesh for time = 1
Time:1  cells:2459155  faces:7641732  points:2723581  patches:5  bb:(-4.1 -4.1 -4.1) (4.1 4.1 4.1)
cellSets:
    isolation    size:2459155
cellZones:
    box    size:1349184
    kula    size:1109971
faceZones:
    box    size:125323
    kula    size:132365
Time = 1
    mesh not changed.
Reading commands from file "batch.setSet"
Please type 'help', 'quit' or a set command after prompt.
Doing:"cellSet isolation new zoneToCell kula"
    Set:isolation  Size:0  Action:new
    Adding all cells of cellZone kula ...
    Found matching zone kula with 1109971 cells.
    Writing isolation (size 1109971) to "1/polyMesh/sets/isolation" and to vtk file "VTK/isolation/isolation_0.vtk"
Doing:"cellSet isolation add zoneToCell box"
    Set:isolation  Size:1109971  Action:add
    Adding all cells of cellZone box ...
    Found matching zone box with 1349184 cells.
    Writing isolation (size 2459155) to "1/polyMesh/sets/isolation" and to vtk file "VTK/isolation/isolation_0.vtk"
Doing:"cellSet isolation subset"
    Set:isolation  Size:2459155  Action:subset
End of batch file
Time = 2
    topology changed; patches unchanged.
    Time:2  cells:2459155  faces:7641732  points:2723581  patches:5  bb:(-4.1 -4.1 -4.10004) (4.1 4.1 4.10005)
    Writing isolation (size 1109971) to "2/polyMesh/sets/isolation" and to vtk file "VTK/isolation/isolation_1.vtk"
    Writing isolation (size 2459155) to "2/polyMesh/sets/isolation" and to vtk file "VTK/isolation/isolation_1.vtk"
End of batch file
End
And then:
subsetMesh -overwrite isolation
Also result of this:
Exec   : subsetMesh -overwrite isolation
Date   : Dec 17 2013
Time   : 12:24:45
Host   : "PC5EJ1"
PID    : 4331
nProcs : 1
Create time
Create mesh for time = 0
Reading cell set from isolation
Adding exposed internal faces to a patch called "oldInternalFaces" (created if necessary)
--> FOAM FATAL ERROR:
Cannot find directory "polyMesh/sets" in times 0 down to constant
    From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
    in file db/Time/findInstance.C at line 142.
FOAM exiting
And here I get the problem... It seems that I should have folder with number "0" and it cause that the further steps cannoy be done.
5. If I am correct, I should now use the splitMeshRegions software:
6. After this step I create (or copy) proper files inside the <regionName> folder (just for further understanding my topic <regionName> in my case will be called "warstwa"). Now I don't really know which name I should pick for the proper assign of boundary layers. In file constant/<regionName>/polyMesh/boundary which in my case is exact copy of the constant/polyMesh/boundary I have written only name allBoundary. I assume that here I will see more names, but due to the error earlier it is just "allBoundary". After this I will use:
So if you have time to look into my problem and tell me:
a) what cause the error in the 4th steps, or how can I prepare 0 folder?
b) Are the 5th and 6th steps correct and will the 6th one be the last, after which I will get the boundary layers inside the cellZones?
Best regards
Andrzej
Old   December 18, 2013, 04:35
Aram Amouzandeh
Hey Andrzej,
the reason why subsetMesh gives an error is that it cannot find the set "isolation" in its default location constant/polyMesh/sets because snappy wrote the mesh info in the two seperate time directories 1/ and 2/. It looks like subsetMesh can only read the needed set from the constant directory, there is not something like a "-time" or "-latestTime" flag (see by typing "subsetMesh -help" in the terminal). In order to get the mesh and the face/cellZones you created with snappy written in the constant directory, use the "-overwrite" flag:
 snappyHexMesh -overwrite
Then
 setSet -batch batch.setStet
will also write the set "isolation" into constant/polyMesh/sets and subsetMesh should work.
After that, when you execute
 splitMeshRegions -cellZones -overwrite
you will get the following two region meshes:
- constant/kula/polyMesh
- constant/box/polyMesh
In addition to the surrounding boundary patches, splitMeshRegions will create an interface patch for each region, i.e. in your case "kula_to_box" in constant/kula/polyMesh/boundary and "box_to_kula" in constant/box/polyMesh/boundary.
snappyHexMeshMR can only use the non-zero patches present in constant/kula/polyMesh/boundary and constant/box/polyMesh/boundary. Hence, if you e.g. want layer addition in the region "box" at the "box_to_kula" patch, you have to use "box_to_kula" in the layers sub-dictionary of the snappyHexMeshDict (which must be stored in system/box) and execute
 snappyHexMeshMR -region box
You ll then get the new mesh in a separate time directory, say 1/. In case you use the overwrite flag like:
 snappyHexMeshMR -overwrite -region box
the mesh with the layers will be written in the constant/box/polyMesh dictionary
All the best!!
Aram
olivier78 likes this.
Old   February 27, 2015, 07:41
Andrzej Prusiński
Dear Aram,
I have tried recently to install your upgrade (snappyHexMeshMR), however it seems that it is not compatible with the newest openFOAM 2.3.1 (or I am making some mistake which leads to this error). The error which I get, when I try to install snappyHexMeshMR looks like this:
SOURCE=snappyHexMeshMR.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam231/src/parallel/decompose/decompositionMethods/lnInclude -I/opt/openfoam231/src/mesh/autoMesh/lnInclude -I/opt/openfoam231/src/meshTools/lnInclude -I/opt/openfoam231/src/fileFormats/lnInclude -I/opt/openfoam231/src/triSurface/lnInclude -I/opt/openfoam231/src/dynamicMesh/lnInclude -I/opt/openfoam231/src/edgeMesh/lnInclude -I/opt/openfoam231/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam231/src/OpenFOAM/lnInclude -I/opt/openfoam231/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/snappyHexMeshMR.o
snappyHexMeshMR.C: In function ‘void writeMesh(const Foam::string&, const Foam::meshRefinement&, Foam::label)’:
snappyHexMeshMR.C:108:44: error: ‘SCALARLEVELS’ is not a member of ‘Foam::meshRefinement’
     meshRefiner.write(meshRefinement::MESH|meshRefinement::SCALARLEVELS, "");
snappyHexMeshMR.C:115:9: error: no matching function for call to ‘Foam::meshRefinement::write(Foam::meshRefinement::debugType, Foam::fileName) const’
snappyHexMeshMR.C:115:9: note: candidates are:
In file included from /opt/openfoam231/src/mesh/autoMesh/lnInclude/autoSnapDriver.H:39:0,
                 from snappyHexMeshMR.C:37:
/opt/openfoam231/src/mesh/autoMesh/lnInclude/meshRefinement.H:1097:18: note: bool Foam::meshRefinement::write() const
             bool write() const;
/opt/openfoam231/src/mesh/autoMesh/lnInclude/meshRefinement.H:1097:18: note:   candidate expects 0 arguments, 2 provided
/opt/openfoam231/src/mesh/autoMesh/lnInclude/meshRefinement.H:1106:18: note: void Foam::meshRefinement::write(Foam::meshRefinement::debugType, Foam::meshRefinement::writeType, const Foam::fileName&) const
             void write
/opt/openfoam231/src/mesh/autoMesh/lnInclude/meshRefinement.H:1106:18: note:   candidate expects 3 arguments, 2 provided
snappyHexMeshMR.C: In function ‘int main(int, char**)’:
snappyHexMeshMR.C:241:5: error: no matching function for call to ‘Foam::searchableSurfaces::searchableSurfaces(Foam::IOobject, const Foam::dictionary&)’
snappyHexMeshMR.C:241:5: note: candidates are:
In file included from snappyHexMeshMR.C:39:0:
/opt/openfoam231/src/meshTools/lnInclude/searchableSurfaces.H:108:9: note: Foam::searchableSurfaces::searchableSurfaces(const Foam::IOobject&, const Foam::dictionary&, bool)
         searchableSurfaces
/opt/openfoam231/src/meshTools/lnInclude/searchableSurfaces.H:108:9: note:   candidate expects 3 arguments, 2 provided
/opt/openfoam231/src/meshTools/lnInclude/searchableSurfaces.H:98:18: note: Foam::searchableSurfaces::searchableSurfaces(Foam::label)
         explicit searchableSurfaces(const label);
/opt/openfoam231/src/meshTools/lnInclude/searchableSurfaces.H:98:18: note:   candidate expects 1 argument, 2 provided
/opt/openfoam231/src/meshTools/lnInclude/searchableSurfaces.H:85:9: note: Foam::searchableSurfaces::searchableSurfaces(const Foam::searchableSurfaces&)
         searchableSurfaces(const searchableSurfaces&);
/opt/openfoam231/src/meshTools/lnInclude/searchableSurfaces.H:85:9: note:   candidate expects 1 argument, 2 provided
snappyHexMeshMR.C:252:5: error: no matching function for call to ‘Foam::refinementSurfaces::refinementSurfaces(Foam::searchableSurfaces&, const Foam::dictionary&)’
snappyHexMeshMR.C:252:5: note: candidates are:
In file included from snappyHexMeshMR.C:40:0:
/opt/openfoam231/src/mesh/autoMesh/lnInclude/refinementSurfaces.H:118:9: note: Foam::refinementSurfaces::refinementSurfaces(const Foam::searchableSurfaces&, const labelList&, const wordList&, const Foam::PtrList<Foam::surfaceZonesInfo>&, const labelList&, const labelList&, const labelList&, const labelList&, const scalarField&, Foam::PtrList<Foam::dictionary>&)
         refinementSurfaces
/opt/openfoam231/src/mesh/autoMesh/lnInclude/refinementSurfaces.H:118:9: note:   candidate expects 10 arguments, 2 provided
/opt/openfoam231/src/mesh/autoMesh/lnInclude/refinementSurfaces.H:110:9: note: Foam::refinementSurfaces::refinementSurfaces(const Foam::searchableSurfaces&, const Foam::dictionary&, Foam::label)
         refinementSurfaces
/opt/openfoam231/src/mesh/autoMesh/lnInclude/refinementSurfaces.H:110:9: note:   candidate expects 3 arguments, 2 provided
/opt/openfoam231/src/mesh/autoMesh/lnInclude/refinementSurfaces.H:99:9: note: Foam::refinementSurfaces::refinementSurfaces(const Foam::refinementSurfaces&)
         refinementSurfaces(const refinementSurfaces&);
/opt/openfoam231/src/mesh/autoMesh/lnInclude/refinementSurfaces.H:99:9: note:   candidate expects 1 argument, 2 provided
snappyHexMeshMR.C:369:5: error: no matching function for call to ‘Foam::meshRefinement::write(Foam::label, Foam::fileName)’
snappyHexMeshMR.C:369:5: note: candidates are:
             bool write() const;
             void write
snappyHexMeshMR.C:404:26: error: ‘class Foam::refinementSurfaces’ has no member named ‘faceZoneNames’
             if (surfaces.faceZoneNames()[surfI].empty())
snappyHexMeshMR.C:576:77: error: no matching function for call to ‘Foam::autoRefineDriver::doRefine(const Foam::dictionary&, Foam::refinementParameters&, const Foam::Switch&, const Foam::dictionary&)’
         refineDriver.doRefine(refineDict, refineParams, wantSnap, motionDict);
snappyHexMeshMR.C:576:77: note: candidate is:
In file included from snappyHexMeshMR.C:36:0:
/opt/openfoam231/src/mesh/autoMesh/lnInclude/autoRefineDriver.H:179:14: note: void Foam::autoRefineDriver::doRefine(const Foam::dictionary&, const Foam::refinementParameters&, const Foam::snapParameters&, bool, const Foam::dictionary&)
         void doRefine
/opt/openfoam231/src/mesh/autoMesh/lnInclude/autoRefineDriver.H:179:14: note:   candidate expects 5 arguments, 4 provided
snappyHexMeshMR.C:614:70: error: no matching function for call to ‘Foam::autoSnapDriver::doSnap(const Foam::dictionary&, const Foam::dictionary&, Foam::scalar&, Foam::snapParameters&)’
         snapDriver.doSnap(snapDict, motionDict, curvature, snapParams);
snappyHexMeshMR.C:614:70: note: candidate is:
In file included from snappyHexMeshMR.C:37:0:
/opt/openfoam231/src/mesh/autoMesh/lnInclude/autoSnapDriver.H:621:18: note: void Foam::autoSnapDriver::doSnap(const Foam::dictionary&, const Foam::dictionary&, Foam::scalar, Foam::scalar, const Foam::snapParameters&)
             void doSnap
/opt/openfoam231/src/mesh/autoMesh/lnInclude/autoSnapDriver.H:621:18: note:   candidate expects 5 arguments, 4 provided
make: *** [Make/linux64GccDPOpt/snappyHexMeshMR.o] Błąd 1
Is it as I said error coming from the difference between the versions and I should consider downgrading my version of openFOAM to 2.2.2?
Regards
Andrzej
Old   May 18, 2015, 15:06
Aram Amouzandeh
Hey Andrze,
please excuse me for my late response!
I did not study the error message in detail but it could be a problem with the version. However, for the case you are using OF 2.3.1 it might be better to use sHM of the same version. In my post from October 30, 2013 I discribed which lines I canged in the code (see the tar.gz files). Hence, copy (in OF 2.3.1 or any other version) the code of sHM into $WM_PROJECT_USER_DIR/applications and change the appropriate lines in the .C file. Compile it with wmake and that's it!
Hope I could still help you.
All the best,
Aram
boundary layer, multi regions, snappyhexmesh
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 15:15
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh crizpi21 OpenFOAM Meshing & Mesh Conversion 5 October 16, 2021 10:56
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
[snappyHexMesh] Could not Add Boundary Layers near a Rectangular Channel Wall using SnappyHexMesh Gary OpenFOAM Meshing & Mesh Conversion 3 July 30, 2018 04:14
[snappyHexMesh] no boundary layers using snappyHexMesh thorsten OpenFOAM Meshing & Mesh Conversion 1 October 22, 2009 06:01
