[mesh manipulation] refineMesh globalCoeffs questions |
February 17, 2012, 10:19 |
Rep Power: 14 |
Does the xyz coordinates systems in refineMeshDict correspond to the x1x2x3 coordinate system that we define in blockMesh ?
My mesh is a box containing only hexes, x1x2x3 coords are defined by the order of my vertices in blockMeshDict. If I want to refine with the same coordinate system as defined in blockMeshDict, do I need to change tan1(1 0 0) and tan2(0 1 0) ? |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing | Regis_ | OpenFOAM Meshing & Mesh Conversion | 2 | June 4, 2015 13:44 |
[mesh manipulation] checkMesh Erros after refineMesh | mgdenno | OpenFOAM Meshing & Mesh Conversion | 10 | October 14, 2014 05:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 11:20 |
checkMesh Errors after refineMesh | mgdenno | OpenFOAM | 0 | July 30, 2012 21:39 |
