Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
snappyHexMesh decomposition error
Like Tree4Likes
  • 1 Post By johnsmith332
  • 3 Post By Ramsky
Old   February 27, 2012, 02:16
Default snappyHexMesh decomposition error
John Smith
johnsmith332 is on a distinguished road
Hi, I'm pretty new at OpenFOAM and I'm trying to so a dsmcFoam simuation using a mesh created with snappyHexMesh. The mesh looks fine in ParaView but I get warnings when I run dsmcInitialise, and the same warnings when I run the simulation which cause it to crash. The error says:
--> FOAM Warning :
From function Foam::List<Foam::FixedList<Foam::label, 4> >Foam::Cloud<ParticleType>::faceTetIndices(label fI, label cI) const
in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 561
No base point for face 25085, 3(3298 2596 2567), produces a valid tet decomposition.
Another warning says:
No base point for face xxxxx, (xxxx)produces a decomposition that has a minimum volume greater than tolerance
I've looked all over the place trying to figure out what's causing this error but with no luck. Does anyone know what this error means or how I might fix it?
e.ahmadiyan likes this.
johnsmith332 is offline   Reply With Quote
Old   April 8, 2013, 02:53
Esmaeil Ahmadiyan
e.ahmadiyan is on a distinguished road
Hi dear johnsmith332
I have same problem as you too. Could you help me to resolve it.
Thanks in advance.
Best regards.
e.ahmadiyan
e.ahmadiyan is offline   Reply With Quote
Old   June 25, 2013, 11:33
Jackie Chou
jackeyhust is on a distinguished road
hi, Esmaeil and John,
have you found the way to solve this problem above? Could you give me a hint for it ? thank you!
best regards,
Jackie
jackeyhust is offline   Reply With Quote
Old   July 29, 2013, 09:57
Ramsky is on a distinguished road
Looks like the problem is with face tets.
If your mesh is generated with snappyHexMesh, try the following:
In snappyhexMeshDict file, look for "minTetQuality".
//- Minimum quality of the tet formed by the face-centre
// and variable base point minimum decomposition triangles and
// the cell centre. Set to very negative number (e.g. -1E30) to
// disable.
// <0 = inside out tet,
// 0 = flat tet
// 1 = regular tet
For a regular tet, it should be positive. Try setting it to 1. If it does not work, set it to a very low positive number. Say 1e-10.
One way to check whether the issue with face tet is resolved or not before the start of the simulation is to do an "checkMesh -allGeometry". It will report if there are any issues with face tets.
Hope this helps.
ramsky
Mojtaba.a, PonchO and alsaeng like this.
Ramsky is offline   Reply With Quote
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
Saving ParaFoam views and case sail OpenFOAM Paraview & paraFoam 9 November 25, 2011 16:46
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
