[CGNS] foamToCGNS converter got Error: wrong number of vertices in cell
Old   March 1, 2012, 17:19
Default foamToCGNS converter got Error: wrong number of vertices in cell
Aqua
aqua is on a distinguished road
Dear all,
I created my mesh in OF1.6ext by snappyHexMesh,
Then try to convert it into cgns by foamToCGNS in OF1.5-dev.
Then error showed up as follows:
Wrong number of vertices in cell
expected 4,5,6, or 8, found 0
From function foamToCGNS
in file writeCGNS.H at line 219.
Could anyone help on this?
Thank you so much!
Aqua
aqua is offline   Reply With Quote
Old   March 1, 2012, 17:58
Aqua
Please, can anyone tell me, CGNS converter doesn't work with snappyHexMesh?
Thank you so much!!
Aqua
Old   March 1, 2012, 18:00
Aqua
It's me again:
Just found some information from the forum in 2008 as follows:
"As of now, the cgnsToFoam converter only supports the following type of 3D cells for unstructured mesh:
tetrahedron (TETRA_4)
pyramids (PYRA_5)
prisms (PENTA_6)
hexahedron (HEXA_8) "
that means, before 2008, it can not handle SHM, but how about now? is there some new version?
Thank you!
aqua
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 10:27
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
