-   OpenFOAM Native Meshers: snappyHexMesh and Others (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/)
-   -   AddLayers on an Airfoil (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/99159-addlayers-airfoil.html)
rdrr84 March 27, 2012 11:41
2 Attachment(s)
Hi Foamers!
I have a problem in creating the Boundary Layer on an airfoil geometry with SHM.
The castellated and snappy phase are ok whereas "addLayers " results in no layer added. Could someone help me?
Thanks a lot
Roberto
I attach the snappyHexMeshDict and the log file for the addLayer phase
lovecraft22 March 27, 2012 12:30
Have you tried this (from your log):
Please set nGrow=0
rdrr84 March 28, 2012 05:42
2 Attachment(s)
Hi!
thx for your answer.
Yes I did it but no layer is added... I also changed the exp ratio to 0.1 to have a greater avg thickness.
Roberto
lovecraft22 March 28, 2012 06:00
I would suggest you to stick with the default parameters and then change only one of them at a time. Every time remember to get rid of every file mesh related.
For example, you set
expansionRatio 0.1;
and there's no point to me in setting this for an airfoil:
/------------------------------------------ Layer 3
| c
/------------------------------------------ Layer 2
| b
/------------------------------------------ Layer 1
|_a_______________________________
/////////////////////////////////////////// Wall
expansionRatio = c/b = b/a
The layers should grow in height when moving away from the wall. In your case they are getting smaller.
Also
finalLayerThickness 0.1;
doesn't make much of a sense to me…
MadsR April 18, 2012 06:06
Do you need snappyHexMesh? If feasible for your airfoil you could use my little airfoil mesher, found here: http://hvirvel.dk/airfoilmesher/
Cheers,
Mads
A.Wendy August 22, 2012 02:46
i have a question to the airfoil mesher. the linked website to worldofkrauss is not working to see the example dat-file. maybe you can show one?
greetings
Andy
wyldckat August 22, 2012 03:19
Greetings to all!
@Andy: Seems like the server for the worldofkrauss website is having bad luck. You can find some information here: http://www.rcgroups.com/forums/showt...3#post22118311 - it seems it was up again in July, but went down again now in August.
Best regards,
Bruno
