April 14, 2015, 18:45 |
Solver crashes - bad mesh?
Jimmy
Rep Power: 10 |
Hi All,
I'm pretty new as a CFD practitioner, especially OF, so bare with me. (My background is in applied aero, as a test engineer.) I'm creating a test case where I want to run compressible flow around a model, with turbulence. I have the model via .stl files, and I'm able to create a mesh via snappyhexMesh. For now, I'm not too worried about how good the mesh is, I just need to go through the process; obviously a good mesh is a goal, just not mandatory at this stage. When I try to run the solver, it gets setup to go, loads info from the various dictionaries, then crashes hard. I realize this is the plight of CFD, just looking for some direction on how to proceed. What I think is happening, due to the following in the snappy output, is the mesh cells are not meeting up properly with the model cells: Code:
total attraction master points: 164912 attraction to: feature point: 0 feature edge: 0 nearest surface: 0 rest: 164912 Any suggestions? |
April 15, 2015, 03:50 |
It would be great, if you could post the complete output of checkMesh
Blog: sourceflux.de/blog "The OpenFOAM Technology Primer": sourceflux.de/book Twitter: @sourceflux_de Interested in courses on OpenFOAM? |
April 15, 2015, 19:01 |
Jimmy
Rep Power: 10 |
I'd rather not, due to the sensitivy of the work. If it's really that critical I can rename the model and post the file for you. Can you give me some suggestions as to what I should be looking for in checkMesh?
A couple things that caught my untrianed eye: At time = 0: Code:
Mesh OK. --> FOAM Warning : From function polyMesh::readUpdateState polyMesh::readUpdate() in file meshes/polyMesh/polyMeshIO.C at line 207 Number of patches has changed. This may have unexpected consequences. Proceed with care And at time = 1, I get: Code:
Checking geometry... Overall domain bounding box (-100 -600 -100) (1200 600 400) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (1.28774e-16 1.06143e-17 -3.51155e-16) OK. Max cell openness = 3.61597e-16 OK. Max aspect ratio = 11.7652 OK. Minimum face area = 0.0335495. Maximum face area = 172.18. Face area magnitudes OK. Min volume = 0.186927. Max volume = 875.888. Total volume = 7.72916e+08. Cell volumes OK. Mesh non-orthogonality Max: 65.0009 average: 9.96491 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 8.22539, 13 highly skew faces detected which may impair the quality of the results <<Writing 13 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End Thanks for any help! |
April 16, 2015, 03:18 |
No problem
April 16, 2015, 12:27 |
Jimmy
Rep Power: 10 |
Forgot to throw this up before...output from the solver (sonicFoam) just before it crashes:
Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RASModel Selecting RAS turbulence model realizableKE realizableKECoeffs { Cmu 0.09; A0 4; C2 1.9; sigmak 1; sigmaEps 1.2; Prt 1; } Creating field kinetic energy K No finite volume options present Starting time loop Time = 0.0125 Courant Number mean: 0.755775 max: 28.4615 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 which: no linux-gate.so.1 in (/home/cfd/OpenFOAM/ThirdParty-2.3.1/platforms/linuxGcc/gperftools-svn/bin:/home/cfd/OpenFOAM/ThirdParty-2.3.1/platforms/linuxGcc/ParaView-4.1.0/bin:/home/cfd/OpenFOAM/cfd-2.3.1/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/site/2.3.1/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/OpenFOAM-2.3.1/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/OpenFOAM-2.3.1/bin:/home/cfd/OpenFOAM/OpenFOAM-2.3.1/wmake:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl) __kernel_sigreturn #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #5 Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 at ??:? #10 __libc_start_main in "/usr/lib/libc.so.6" #11 at ??:? Floating point exception (core dumped) Thanks! |
April 17, 2015, 03:57 |
I'm not familiar with sonicFoam, but the maximum Courant number is 28. Try to decrease it.
April 20, 2015, 09:46 |
resolution
Jimmy
Rep Power: 10 |
See this post for the resolution I came across to my problem:
http://www.cfd-online.com/Forums/ope...tml#post542729 And regarding Courant number, I did modify my original mesh and reduce the timestep to get it more reasonable. Thanks for the help everyone. Cheers! |
code validation, snappyhexmesh, surfacefeatureextract |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
mesh quality problem for displacementSBRStress motion solver | zhaozhenkai | OpenFOAM | 0 | January 22, 2017 12:02 |
[ICEM] Bad Quality | **Anny** | ANSYS Meshing & Geometry | 7 | May 28, 2015 06:03 |
PimpleFoam: Solver Crashes for simple laminar flow | mayank.dce2k7 | OpenFOAM Running, Solving & CFD | 0 | May 1, 2014 21:53 |
Solver Error for fine mesh in translationally periodic element | AliLemprex | CFX | 3 | March 26, 2014 15:32 |
