February 9, 2016, 08:59 |
mesh quality requirement
stefano zinna
Rep Power: 17 |
Hi All,
Do you know if there is a general guidlines for quality reuirement in openfoam. Something like: mesh should have orthogonality less than..., aspect ratio less than ... etc.. I know that it is case dependent but i am looking for a "first guess" guidlines. regards, Stefano |
February 9, 2016, 10:34 |
gereksiz
Rep Power: 11 |
I also wonder how accurate the checkMesh of OF.
March 19, 2016, 15:43 |
Vinícius da Costa Ávila
Rep Power: 10 |
Hi, I am no expert, but as you said, it depends HIGHLY on the solvers you use.
Also, OF has a standard limiting values for mesh quality with checkMesh (these standard values are mostly for reference, since they can be changed by the user). Standar values used in OF ($WM_PROJECT_DIR/src/OpenFOAM/meshes/primitiveMesh/ primitiveMeshCheck/primitiveMeshCheck.C) • Foam::scalar Foam:rimitiveMesh::closedThreshold_ = 1.0e-6; • Foam::scalar Foam:rimitiveMesh::aspectThreshold_ = 1000; • Foam::scalar Foam:rimitiveMesh::nonOrthThreshold_ = 70; // deg • Foam::scalar Foam:rimitiveMesh::skewThreshold_ = 4; • Foam::scalar Foam:rimitiveMesh:lanarCosAngle_ = 1.0e-6; For example, for a case I'm used running: tutorial bubbleColumn with RAS turbulence models, I am able to run big meshes (more than a million cells) with the standard numerical solvers (fvSchemes and fvSolution) and Co=1.0 even with not very good meshes (but still within checkMesh quality limits) and I get accurate results. In my (brief) experience I would recommend as a start point: Aspect ratio: max 5-10 nonOrtho.: max 50-60 skewness: max 1-2.5 Then, I recommend mesh convergence studies to be made. So it will ensure your solution is mesh independent.
Vinícius dC.A. |
Display Modes | |
[snappyHexMesh] very bad quality snapped mesh | federicabi | OpenFOAM Meshing & Mesh Conversion | 18 | September 26, 2018 11:33 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
[snappyHexMesh] Improving mesh quality + inlet too coarse | MartinBlx | OpenFOAM Meshing & Mesh Conversion | 5 | August 2, 2015 23:09 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
mesh quality and independency..!?? | michelle | CFX | 0 | October 15, 2007 06:50 |
