Home > Forums > OpenFOAM Meshing Format & General Technical
Creating your own mesh files
Like Tree1Likes
Old   August 6, 2007, 14:04
Default Thanks Mattijs. That helps in
  #21
Daniel Einstein
deinstein is on a distinguished road
Thanks Mattijs. That helps in terms of the faces and boundaries. It is a pretty strict format but so be it. Any guidance on binary vs. ascii?
Dan
deinstein is offline   Reply With Quote
Old   August 6, 2007, 14:50
Default If using OpenFOAM writing bina
  #22
Mattijs Janssens
mattijs is on a distinguished road
If using OpenFOAM writing binary is pretty easy. Construct a regIOObject (e.g. labelIOList) and write with writeObject(..) using streamFormat=BINARY.
If using outside code writing binary is quite hard. Use ascii would be my advice. In 1.4.1 there is the foamFormatConvert to convert mesh files from binary to ascii and vice versa.
mattijs is offline   Reply With Quote
Old   August 6, 2007, 15:05
Default Hmm. My situation would be the
  #23
Daniel Einstein
Hmm. My situation would be the latter. The ascii files are huge. You probably hear that a lot. An ascii --> binary utility would be helpful, if a patch, for the future.
I know it is relatively late in the game, but if you guys are in the mood to entertain suggestions, I would suggest an approach similar to the vtk XML unstructured grid format, whereby the ascii header indicates Little or Big Endian as well as type definitions. This will help to make everything as device independent as possible.
Dan
Old   August 7, 2007, 05:21
Default Hi Daniel! But OpenFOAM rea
  #24
Assistant Moderator
Bernhard Gschaider
Hi Daniel!
But OpenFOAM reads gnuzipped files transparently (the content is ascii). And these should be even smaller than the binary files. Because (correct me if I'm wrong, I hardly ever use the binary-format) in the binary files all digits get stored wheras in the Ascii-files only the number of digits specified in the controlDict get stored. And if "less information" is zipped according to Shannon it should be always smaller than the binary (which contains more information)
I think the ascii/gnuzipped variation has both advantages: less storage (even if you write all digits) and being VERY portable.
@xml: As I understand it the file format of OpenFOAM was specified before everyone and his dog was using XML (I don't know if XML was then even specified). For all practical purposes it looks rather XMLy to me (structured etc). It just doesn't look like XML (that's enough Zen for today)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 11, 2007, 05:16
Default Hi all, i am a new user of
  #25
soufymer
soufy is on a distinguished road
Hi all,
i am a new user of openfoam. and i find a diffeculty to use it . please i need a help.
my question is: it is possible to import a geometrie in formet ".step " from a CAD ( for exemple solidworks ).
because for the complexe geometrie it's difficult.
please it's urgent!!!!!
soufy is offline   Reply With Quote
Old   January 1, 2009, 01:24
  #26
NAVEEN.K.M
naveen is on a distinguished road
Hi all,
my question is: is it possible to import a geometry in formet ".msh " from a fluentmeshTofOAM AND GAMBIT TO FOAM....
naveen is offline   Reply With Quote
Old   January 4, 2009, 11:35
Default If you have a .msh file, use f
  #27
Francesco Del Citto
fra76 is on a distinguished road
If you have a .msh file, use fluentMeshToFoam or fluent3DMeshToFoam to convert it to OpenFOAM (you need a "minimal" case to work in; copying a tutorial case could be a good starting point).
If you find any problems with those tools, post the error in the forum...
Hope this helps,
Francesco
fra76 is offline   Reply With Quote
Old   March 12, 2009, 04:25
Default Hello! I'd like to create a s
  #28
Hansjoerg Seybold
hansjoerg is on a distinguished road
Hello!
I'd like to create a simple but HUGE(~500^3) block structured mesh from voxel tomography data.
(file of binary values 0,1, cubic blocks)
I tried to create a blockmesh dict with a script but I run out of memory when using blockmesh.
Also the mesh finally has to be decomposed for multiple CPU.
Does anybody have a idea how i can handle this problem.
thanks
hansjoerg
P.S. Sorry for double posting, but i've put it by accident in the gambit thread
hansjoerg is offline   Reply With Quote
Old   April 9, 2009, 07:36
Default Get points of a face
  #29
Xabi is on a distinguished road
Hi all!
Do anyone know how to get the points that define a surface?
Writing: mesh_faces()[i] I obtain the label with the four points for the face [i] but I am not able to split it up in order to thereafter read the number of point and get their values from the "points" file.
Thanks in advance.
Xabi
Xabi is offline   Reply With Quote
Thread Tools
Trackbacks are On
creating geometry using "Script files" in ICEMCFD jaber Main CFD Forum 1 November 11, 2007 10:28
creating CFX mesh igor CFX 0 January 15, 2007 19:25
Creating a 2D Mesh using ICEM VSB CFX 0 November 1, 2006 23:17
Creating a mesh in Gambit Vidya Raja FLUENT 3 October 3, 2005 10:45
creating mesh using Gambit Rucy Hong FLUENT 3 April 26, 2005 23:27
