Home > Forums > OpenFOAM Meshing Format & General Technical
Mapping cell faces to other cell faces
Old   March 27, 2007, 13:10
Default I'm relatively new to OpenFOAM
Doug Hunsaker
doug is on a distinguished road
I'm relatively new to OpenFOAM, and am looking for a way to map cell faces to other cell faces. I've created my own mesh and have written the OpenFOAM files for it. It is a C mesh that wraps around an airfoil, and I need to map the two trailing regions of the mesh to each other. I know there must be a way to do it, but haven't been able to find anything in the documentation. Any direction would be helpful.
Thanks.
-doug
doug is offline   Reply With Quote
Old   March 27, 2007, 13:22
Default You can find a cell model deco
Hrvoje Jasak
You can find a cell model decomposition used in OpenFOAM in
OpenFOAM-1.3/.OpenFOAM-1.3/cellModels.
Should be self-descriptive.
Hrv
Hrvoje Jasak
Old   March 27, 2007, 13:28
Default Where's that directory? I can'
Doug Hunsaker
Where's that directory? I can't find it in my directories.
Thanks.
-doug
Old   March 27, 2007, 15:47
Default I've found a mesh manipulation
Doug Hunsaker
I've found a mesh manipulation function called stitchMesh. Does anyone have an example file of how I would use it?
-doug
Old   March 27, 2007, 21:14
Default Hi Doug! Another way to fin
Assistant Moderator
Bernhard Gschaider
Hi Doug!
Another way to find cellModels is
$WM_PROJECT_DIR/.OpenFOAM-1.3/cellModels
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 30, 2007, 02:43
Default Hi Doug, I think stichMesh is
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Doug,
I think stichMesh is the tool you need. There is a very short HowTo on the wiki, that might suit you.
Have a look: stitchMesh HowTo
Dragos
dmoroian is offline   Reply With Quote
Thread Tools
Trackbacks are On
Loop over the faces of a cell in UDF Anthony Wachs Fluent UDF and Scheme Programming 5 September 20, 2015 07:22
Pick out cell faces Jorge CD-adapco 6 June 20, 2005 15:10
Defining cell faces in BFC Olof Liungman Phoenics 2 July 28, 2003 04:23
Looping over faces in a cell Senthil FLUENT 3 April 11, 2002 11:41
Metrics of Transformation at the cell faces? Mohammad Kermani Main CFD Forum 0 February 23, 2000 15:04
