[snappyHexMesh] SnappyHexMesh STL patch naming
Old   July 23, 2008, 04:07
Default SnappyHexMesh STL patch naming
Gregor Veble
gregorv is on a distinguished road
First of all, thank you OpenFOAM team for a marvelous utility that is snappyHexMesh. It has been exceeding my expectations so far.
There is a minor problem I have with the naming of patches that belong to different entries in an STL file. Is it possible to specify a single patch for all the different "solid" entries in one STL file?
From what I have seen so far, there are separate patches generated with respect to the different "solid" entries in the STL file in ASCII format, appending the solid name to the specified base name. When I tried to import a binary file (my preferred way), it seemed to want to create a large number of patches, possibly one per triangle (I am not sure about this though). What is the way to avoid this behaviour?
gregorv is offline   Reply With Quote
Old   July 23, 2008, 07:05
Default If this is only happening with
Eugene de Villiers
eugene is on a distinguished road
If this is only happening with binary format STL files, then I guess you have found a bug and should report it as such. If it is happening because your surface meshing utility has really defined each triangle as a different solid, then I suggest you address the problem at the upstream end.
eugene is offline   Reply With Quote
mapFields Error with snappyHexMesh Source Added Layers sherif35 OpenFOAM Pre-Processing 0 September 29, 2014 17:01
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
chtMultiRegionFoam Tutorial m.nichols19 OpenFOAM 12 September 9, 2010 11:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
