March 26, 2008, 04:39 |
Netgen and surfacecheck
Mark Couwenberg
Rep Power: 17 |
L.S.,
Can anyone explain me how to use the tool surfaceCheck? Do I have to compile it first? And how? I have a geometry which is very hard to mesh in Salome, using Netgen. Allthough the build-in geometry checks in Salome say that everything is fine, meshing fails all the time. If anyone is willing to check my files, I can send them. It don't manage to copy them in this post. Mark |
March 27, 2008, 15:43 |
surfaceCheck is in the standar
Mattijs Janssens
Rep Power: 26 |
surfaceCheck is in the standard release. The things to check for is that your surface is manifold/closed (i.e. every edge has two faces). Netgen has problems if your cell size is bigger than the feature size. Try meshing with more tets.
[Netgen] Netgen .stl file import - segmentation fault | Artur | OpenFOAM Meshing & Mesh Conversion | 0 | May 19, 2013 15:14 |
[Commercial meshers] Harpoon to Foam | Manuel Garcia (Garcia) | OpenFOAM Meshing & Mesh Conversion | 58 | March 25, 2008 18:38 |
[Netgen] Import stl file netgen writes segmentation faulterror | unoder | OpenFOAM Meshing & Mesh Conversion | 8 | October 2, 2005 10:26 |
