Plot3DtoFoam conversion error
Hi everybody,
I'm trying to import a 2d naca profile written in Plot3d but I get the following error: Exec : plot3dToFoam /home/dino/OpenFOAM/dino-1.4.1/run/tutorials/potentialFoam/ nacaPotential naca_0012.xyz Date : Mar 29 2008 Time : 11:51:46 Host : ime054 PID : 5316 Root : /home/dino/OpenFOAM/dino-1.4.1/run/tutorials/potentialFoam/ Case : nacaPotential Nprocs : 1 Create time Reading 1 blocks xDim:257 yDim:129 zDim:1 Reading block points block 0: --> FOAM FATAL IO ERROR : Attempt to get back from bad stream file: naca_0012.xyz at line 5. From function void Istream::getBack(token& t) in file db/IOstreams/IOstreams/Istream.C at line 44. FOAM exiting I don't know if this utilities needs a 3d mesh to convert, but if I remember correctly openfoam automatically introduce a third dimension. Thank you in advance for any support. dino |
