-   OpenFOAM Meshing Format & General Technical (http://www.cfd-online.com/Forums/openfoam-meshing-technical/)
-   -   MergeMeshes (http://www.cfd-online.com/Forums/openfoam-meshing-technical/61933-mergemeshes.html)
hsieh May 18, 2006 22:25
Dear OpenFOAM experts, I am
I am wondering about mergeMeshes utility and the sitichMeshes utility.
I am planning to "glue" two meshes together. In the OpenFOAM wiki site, the description of mergeMeshes if the following:
mergeMeshes adds the cells of two meshes together. It does NOT merge the faces between the two sets of cells. Neither does it check for overlapping cells.
To merge the faces use stitchMesh.
So, does it mean that I will perform
mergeMeshes <master> <master> <second> <sencond>
Followed by:
stitchMeshes <case> <case> <patch> <patch>
in stitchMeshes, does it "merge" the faces and also eliminate duplicate nodes?
Thanks in advance for your reply.
Pei
nanavati September 10, 2014 05:12
Followed by:
Pei
Hi, Did you found any example on SticthMesh so far ?
Please let me know.
I am struggling for the same and unfortunatelly there is no exact complete StitchMesh Example available !!
elvis September 10, 2014 07:32
http://openfoamwiki.net/index.php/StitchMesh
http://openfoamwiki.net/index.php/Im...ith_interfaces
nanavati September 10, 2014 09:15
Thanks for the links.
In the Meanwhile, I have found one more complete tutorial.
http://www.tfd.chalmers.se/~hani/kur...eTutorials.pdf
Hope, this thread and these links will be helpful to those who are searching the stuff out there :)
