Home > Forums > OpenFOAM Meshing Format & General Technical
Tetrahedral meshes
Old   December 14, 2004, 21:10
Default Hi, I have a fairly naive
Damian Merrick (Merrick)
I have a fairly naive question about meshing. I'm currently experimenting with interFoam, as my problem involves simulating dripping and flow of fairly thin films of water (air is the other phase).
I've created a simple test case consisting just of a cube with edge length 10cm, and have set the gamma to 1 in a small region at the top, on one of the sides of this cube (the region is a cube of 5mm edge length). When I mesh this region using blockMesh (with 20x20x20=8000 hexahedral cells), the interFoam solution proceeds perfectly, and the results look fine. However, when I use a tetrahedral mesh for the box (I'm using tetgen at the moment, the mesh I generated was about 12000 tetrahedra from memory), the simulation seems to become unstable - the Courant number blows out to something large, and if I have adaptive time steps enabled the deltaT becomes smaller and smaller.
Does this simply mean that I'm using a bad quality mesh? Are there any tools I can use to discover what the problems are, or alternatively can anyone suggest a better meshing tool? I have run checkMesh on the triangulated mesh and its tests return OK (there are 4 severely non-orthogonal facets out of 4800, everything else was fine).
Obviously using a tetrahedral mesh for this particular example isn't important, but the geometry I'm aiming to use in the future will be triangulated data from a CAD package, so I assume I'll be unable to use blockMesh in that case.
Thanks,
Damian.
Old   December 14, 2004, 21:29
Default Oh, it will work - the mesh d
Hrvoje Jasak (Hjasak)
Oh, it will work - the mesh doesn't sound too bad. The point here is that default setting are made for speed and accuracy, not robustness. Therefore, you will need to adjust the fvSchemes and fvSolution and maybe the solver tolerances (time to get some CFD experience with FOAM) :-)
Off the top of my head, I would say add 1 non-orthogonal corrector and pay attention on what the solver is doing. The PISO loop should converge the pressure at least 2 orders of magnitude. Play with non-orth correctors, number of PISO correctors and max Co number.
A word of warning: the old rule of "rubbish in-rubbish out" still applies. If you've got a bad mesh you will not get a good solution. More importantly, because the solver is set up to give accurate results (and fast!) for decent meshes, you will see a performance hit bigger than in commercial codes (that's because they are set up to deal with bad meshes by default and that makes them slower). Therefore, a good mesh means a good solution AND getting it faster!
Enjoy,
Hrv
Thread Tools
Trackbacks are On
SimpleFoam and tetrahedral meshes edreed OpenFOAM Running, Solving & CFD 2 May 15, 2008 14:59
IcoDyMFoam and tetrahedral meshes ulrich_lange OpenFOAM Running, Solving & CFD 11 April 16, 2007 16:44
SFCD in tetrahedral meshes cosimobianchini OpenFOAM Running, Solving & CFD 2 March 6, 2007 12:21
Issues with tetrahedral tetra meshes billy OpenFOAM Running, Solving & CFD 0 May 8, 2006 18:03
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
