Home > Forums > OpenFOAM Meshing Format & General Technical
removing the 'hole' close to the axis
Old   March 17, 2009, 08:29
Default removing the 'hole' close to the axis
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
I have a mesh with a hole in the center.
I tried just moving the points towards the axis. which created other problems, like
zero area faces. No surprise really.
I suspect that I also need to loop over the faces and change the connectivity.
Will this be sufficient though?
If so, any example here of how to reconstruct the mesh with the new faces and points would be appreciated.
N
niklas is offline   Reply With Quote
Old   March 18, 2009, 04:03
Mattijs Janssens
mattijs is on a distinguished road
Tried collapseEdges?
mattijs is offline   Reply With Quote
Old   March 23, 2009, 05:48
niklas's Avatar
Niklas Nordin
yes, but its either core-dumping or producing really crappy meshes.
Probably because I dont know how to use it
Thread Tools
Trackbacks are On
How to specify the axis in 2D axis-symmetric case? B FLUENT 4 February 9, 2009 10:09
ICEM, Tetra removing Mikhail CFX 1 July 24, 2008 11:07
Removing lines from partitions Josh FLUENT 7 July 27, 2007 10:33
Installing 12 after removing 11 maka OpenFOAM Installation 5 August 26, 2005 17:17
removing conduction term Philippe Salama FLUENT 1 June 3, 2005 12:12
