[mesh manipulation] bubblecolumn with obstacles
Old   May 30, 2009, 05:45
Default bubblecolumn with obstacles
Wouter van der Meer
wouter is on a distinguished road
hello All,
I would like to model a bubble column with some internals, but I cannot pass the first obstacle. I cannot create a 2D mesh of a column with an obstacle. I get the errormessage:
Trying to specify a boundary face 4(5 9 25 21) on the face on cell 3 which is either an internal face or already belongs to some other patch.
Can anybody enlighten me. I am new to CFD and Linux.
wouter is offline   Reply With Quote
Old   May 31, 2009, 07:57
Henrik Rusche
henrik is on a distinguished road
Dear Wouter,
there is a problem with you mesh. But it seems to be on cell rather block level. Is the error message from blockMesh? If yes, please post the blockMeshDict.
Did you start from an example? Which one? Did it work when you took it out of the box? What did you do to break it?
Henrik
henrik is offline   Reply With Quote
Old   May 31, 2009, 08:59
Wouter van der Meer
blockMeshDict.gz
Hello Henrik,
Thanks for taking the time. I tried the bubbleFoam tutorial and wanted to insert a slanted block. ( I changed the meshDict from my first post) I made 9 blocks and the middle block was supposed to be a slanted wall. The bubbles are supposed to swirl round.
Wouter
Old   June 1, 2009, 07:32
Talking found error
Wouter van der Meer
In the second block description vertex 23 should have been vertex 22
Old   June 1, 2009, 23:30
Henrik Rusche
Thanks for letting us know that you fixed the problem. Henrik
[ANSYS Meshing] problem in meshing of Aerofoil shaped obstacles in plane channel. lohith ANSYS Meshing & Geometry 0 June 20, 2018 02:58
[blockMesh] Creating Removable Obstacles fatirishman53 OpenFOAM Meshing & Mesh Conversion 0 July 1, 2017 14:22
3d bubbleColumn multiphaseEulerFoam P_P OpenFOAM Running, Solving & CFD 0 March 25, 2014 08:29
Jet impingement on cylindrical obstacles robmuggleton FLUENT 1 October 21, 2013 18:08
Cylindrical obstacles in cartesion coordinates Brajesh Tripathi Phoenics 4 July 16, 2007 00:23
