[Technical] Why are hex meshes better than tet?
Old   May 14, 2009, 09:54
Default Why are hex meshes better than tet?
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
I have been looking around a bit for a while and I can't seem to find why hex meshes are better than tet meshes, in finite volumes.
I was able to find papers for finite element, but not finite volume.
Can anybody point me in the right direction to where I might read up on this, or even briefly explain why?
Best Regards,
Philip
bigphil is offline   Reply With Quote
Old   May 15, 2009, 05:26
Wolfgang Heydlauff
wolle1982 will become famous soon enough
hi bigphil,
hex mesh are usually structured, so the cell-koordinates can easily be transformed into the calculation matrx (i,j,....).
the tet-meshes usually are unstructured. that's why there is the need for a transformation matrx. while calculation the cpu has to read out the calculation matrx for each timestep.so calculation time is longer.
furthermore a tetraeder has sharper angles than an hexaeder. in FVM the flux is calculated scalar, so sharp angles should be avoided.
wolle1982 is offline   Reply With Quote
Old   May 15, 2009, 05:47
bigphil's Avatar
Philip Cardiff
Wolfgang,
Thanks very much for enlightening me.
So in general, hex are more accurate and take less time.
Best Regards,
Philip
Old   May 15, 2009, 14:24
Gijsbert Wierink
gwierink is on a distinguished road
That's right. Also, a tet mesh can have very skewed cells, especially when your geometry contains different shapes (e.g. a cube in a relatively small cylinder).
gwierink is offline   Reply With Quote
Old   May 18, 2009, 09:01
bigphil's Avatar
Philip Cardiff
Gijsbert,
Thanks for the reply.
Old   May 18, 2009, 11:19
bigphil's Avatar
Philip Cardiff
I have one more question:
How does the cell shape affect convergence of the solution?
I have found that if I use quite skewed cells, then my case will not converge.
Is this a general rule or how does the cell shape affect convergence?
Thanks,
Philip
Old   May 18, 2009, 14:03
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Skewed elements are sometimes "bad" because the fluxed over their boundaries are calculated wrong and have to be treated with "corrected" schemes.
I can give you some literature reference about that, but I have to look it up.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   May 18, 2009, 14:13
bigphil's Avatar
Philip Cardiff
Hi Sega,
I would love if you could give me some literature reference, that would be great!
Thanks you.
Philip
Also, does all this apply equally to stress analysis as it does to fluid dynamics?
Old   May 18, 2009, 14:30
sega's Avatar
Sebastian Gatzka
Hi.
Have a look at this picture
It may illustrate the basic problem when dealing with skewed elements (so called non-othogonal grids).
Basically when interpolating from the cell centers to the face the midpoint of the face is not matched with the connecting line between the two cell centers thus creating a erroneous flux.
You can deal with it by using corrected schemes (first of all for snGrad!).
The "strength" of the correction can by controlled by the entry behind nOrthogonalCorrectors. (There has been a discussion about this entry before.)
The above picture is from:
M. Schäfer. Computational Engineering. Springer 2008. (Chapter 4.5).
And there are some lines at
Ferziger. Computational Methods for Fluid Dynamics. Springer 2002 (Chapter 8.6.2 I think).
Hope this helps. Have a nice day.
Old   May 19, 2009, 05:45
bigphil's Avatar
Philip Cardiff
Sega,
Thanks you very much, this really helps.
I will have a look through Schafer and Ferziger, and I will also have a look around the forum.
Kind Regards,
Philip
Old   July 18, 2016, 12:20
Default Hex vs Tet Help, please
  #11
Roberto
RobBanks is on a distinguished road
Hello Everyone!
Sorry for posting on this quite old forum...
I'm pretty new to the CFD simulation process and I'm still learning about the pros and cons of Hexes vs Tets. According to my investigation, for my CAD model it would be better to use Hexes rather than Tets, but I feel I have still no solid basis to state this, so, as I'm really new to this, I was wondering if any of you could recommend me any beginners literature on the pros and cons of Hexes and Tets and/or a guide to understand in which cases it is best to use hexes or tets or how to come up with an accurate solution to this problem.
Thanks in advance for any of your helpful replies.
RobBanks is offline   Reply With Quote
[blockMesh] --> FOAM FATAL ERROR: Trying to specify a boundary face A.A. OpenFOAM Meshing & Mesh Conversion 41 June 26, 2020 07:06
[Other] mergeMatchPairs with arcs vainilreb OpenFOAM Meshing & Mesh Conversion 1 August 5, 2013 08:11
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 01:18
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
