Home > Forums > OpenFOAM Meshing Format & General Technical
bubble in blockmesh
Old   June 23, 2009, 17:37
Default bubble in blockmesh
Rickard Hidefjäll
SkunkWorks is on a distinguished road
Hi !
I have tried to make a hole in 3d, I mean like a air bubble in water.
But I have got a strange error message from blockmesh.
What I really try to so is a aircraft in a virtual wind tunnel there the bubble is the aircraft.
Have any one tried to do some thing like this?
Are there any other solutions on this problem?
SkunkWorks is offline   Reply With Quote
Old   June 24, 2009, 04:11
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Maybe there is a solution if you give us some detail on the error message.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   June 24, 2009, 04:50
Rickard Hidefjäll
Hi!
I'm trying with different node order on the inner face.
look at the picture that I'm made in gmsh to make the work it easier.
http://www.tooslow.net/rattus/cfdonline/MshBubble.gif
And here is the output from bash.
http://www.tooslow.net/rattus/cfdonl...hTestrun_1.txt
Here is the blockMeshDict
http://www.tooslow.net/rattus/cfdonline/blockMeshDict
As you can see, I have tried to make the inner walls oriented the other way around
The case is a modify /home/rickard/OpenFOAM/rickard-1.5/run/tutorials/icoFoam/cavity
Regards / Rickard Hidefjäll
Old   June 24, 2009, 05:09
Rickard Hidefjäll
You can see at
http://www.tooslow.net/rattus/cfdonl...el20090305.jpg
http://www.tooslow.net/rattus/cfdonl...20090305_2.jpg
http://www.tooslow.net/rattus/cfdonl...20090305_3.jpg
http://www.tooslow.net/rattus/cfdonl...20090305_4.jpg
what I try to do. This is done in Gmsh. But I can't find any solution that takes gmsh mesh.
OpenFoam can convert it but only with gmsh1.*.
And I've tried to complie Gmsh2ToFoam but my it dont work with OF 1.5.
Thread Tools
Trackbacks are On
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Bubble Diameter Santi FLUENT 3 March 4, 2010 11:56
Separation bubble, hypersonic compression corner ben akih CFX 3 December 10, 2006 17:33
gas hold up in bubble Shelly Main CFD Forum 0 November 13, 2006 01:28
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 01:02
