Home > Forums > OpenFOAM Meshing Format & General Technical
Uncovered faces found ????
Old   July 3, 2009, 13:08
Default Uncovered faces found ????
Steve Hansel
hansel is on a distinguished road
I'm using OpenFOAM-1.5-dev Ubuntu 9.04 64 bit.
I'm attempting to set up a rotating mesh, with a cylinder inside a block with a hole, just a little larger than the cylinder. (the cylinder is about 2M across and the gap is 0.5mm) See picture at end.
When I run it, I get this error:
From function void GGIInterpolation<MasterPatch, SlavePatch>::rescaleWeightingFactors() const
in file /storage/software/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/GGIInterpolationWeights.C at line 533
Uncovered faces found. On master: 98 on slave: 504
Largest slave weighting factor correction : 0.4458582 average: 0.04798944
Largest master weighting factor correction: 1 average: 0.2857143
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
alphaEps 0.76923;
Reading field rAU if present
Starting time loop
Courant Number mean: 0.002633346 max: 0.02407465 velocity magnitude: 1.107188
Time = 2.001
Segmentation fault
What is an uncovered face? Does it have to do with the two meshes not lining up perfectly?
I tried it with several different programs:
turbDyMFoam - error and crash
icoDyMFoam - error and crash
IcoFoam error message, doesn't crash, good results.
PotentialFoam error message, no crash, strange results. (velocity changes through ggi interface, like light through a lens.)
traceback on the crash is:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7f7dd8b7d700 (LWP 6293)]
0x00007f7dd8768124 in Foam::mixerGgiFvMesh::calcMovingMasks () from /storage/software/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdynamicFvMesh.so
Current language: auto; currently asm
(gdb) where
#0 0x00007f7dd8768124 in Foam::mixerGgiFvMesh::calcMovingMasks () from /storage/software/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdynamicFvMesh.so
#1 0x00007f7dd87690ad in Foam::mixerGgiFvMesh::movingPointsMask () from /storage/software/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdynamicFvMesh.so
#2 0x00007f7dd87690eb in Foam::mixerGgiFvMesh::update () from /storage/software/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libdynamicFvMesh.so
#3 0x0000000000416047 in main ()
(gdb) list
1 /build/buildd/glibc-2.9/build-tree/amd64-libc/csu/crtn.S: No such file or directory.
in /build/buildd/glibc-2.9/build-tree/amd64-libc/csu/crtn.S
(gdb) Quit
Thanks
hansel is offline   Reply With Quote
Old   July 3, 2009, 13:09
Steve Hansel
BTW, the GGI questions and answers are spread all over the place. I think there should be an OpenFOAM -> Meshes -> GGI / moving meshes section.
Old   July 3, 2009, 23:53
Steve Hansel
Okay, I made some progress. The uncovered faces are just what it sounds like. When I made my face zones I included the top and bottom. I should have just had the mating faces. So that error is gone.
Unfortunately I'm down to just a core dump with no explanation. It's somewhere in the GGI when it's moving the mesh.
Old   July 4, 2009, 04:41
Nugroho Adi
mahaputra is on a distinguished road
Dear Hansel
sorry, just wondering
which meshing generator/tool you use for meshing your posted geometry? (a box with a circle inside)
thanks
mahaputra is offline   Reply With Quote
Old   July 4, 2009, 11:25
Steve Hansel
Originally Posted by mahaputra View Post
Dear Hansel
thanks
I used blockMesh for the basic cylinder and block. Once I get this working, I plan to carve the test item out of the cylindar using snappyHexMesh.
By the way, if I can ever make this work, I'll write up step by step instructions on how I did it to make it easier for everyone else.
Old   July 10, 2009, 14:05
Default ggi
Hasselhoff is on a distinguished road
Hi everybody
That's right- it's hard to get ggi- related information. It would be nice if there was some faq somewhere GGI worked out real nice for me for nonrotatin and overlapping interfaces- If someone needs information about that, feel free to ask
But if I add some nonoverlapping Interfaces, the whole thing doesn't work quite long. I guess the difficulty is how to declare the bridgeOverlap.
The Mesh was generated in Gambit, the Solver is rhoSimpleFoam. The Pictures (interfaces) show the top of a turbomachinery component, walls are periodic.. The flux is supposed to go from the inside through the Honeycomb area.
The honeycomb structures are meshed tri, block (inside) is meshed hex.
My boundary file looks like the following:
HoneyComb_Step
type ggi;
nFaces 221;
startFace 1476442;
shadowPatch Step;
zone zone_ HoneyComb_Step;
bridgeOverlap true;
Step
type ggi;
nFaces 40;
startFace 1476663;
shadowPatch HoneyComb_Step;
zone zone_ Step;
bridgeOverlap true;
HoneyComb_Level_2
type ggi;
nFaces 2880;
startFace 1476703;
shadowPatch Level_2;
zone HoneyComb_Level_2;
bridgeOverlap true;
Level_2
type ggi;
nFaces 1289;
startFace 1482568;
shadowPatch HoneyComb_Level_2;
zone zone_Level_2;
bridgeOverlap true;
HoneyComb_Level_1
type ggi;
nFaces 2985;
startFace 1479583;
shadowPatch Level_1;
zone zone_ HoneyComb_Level_1;
bridgeOverlap true;
Level_1
type ggi;
nFaces 1064;
startFace 1483857;
shadowPatch HoneyComb_Level_1;
zone zone_Level_1;
bridgeOverlap true;
is there a mistake in my boundary- file? Thank you for answering!
best, Mitch
Hasselhoff is offline   Reply With Quote
Thread Tools
Trackbacks are On
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
