[Technical] General meshing-question for simple (thermal) problem
Old   October 13, 2009, 12:55
Default General meshing-question for simple (thermal) problem
suitup is on a distinguished road
Hello, i'm really new at cfd, so i've a general questions about meshing.
(I'm working with salome.)
I wanna simulate a simple thermal problem: a solid cube with a heat-source in a bigger cube, the bigger cube should be a fluid (e.g. simple air)
My idea is, that i create two cubes and each cube has an 3D-Mesh. Both are volume- solids in salome, the smaller one should be a real solid and the other one should be later declared in OF as fluid.
Is it the right way?
Thanks.
PS: How can I create the inner cube without overlapping with the mesh of the "air"-cube? Creating the little cube using the cutting-function to cut the form out of the bigger cube and then creating a new small cube, or is there an easier way?
suitup is offline   Reply With Quote
Old   November 26, 2010, 16:15
Thomas Walsh
thomasnwalshiii is on a distinguished road
i believe the easiest way to do this would be to just use the blockmesh tool within OpenFOAM. Take a look at the chtMultiRegionFoam tutorial cases. change the initial blockmesh boundary file to correspond with your larger box (the air) and change the setset file to make the inside box (your solid). you will then have to go through and correct all the boundary conditions. Once you gemoetries increase in complexity you will probably have to switch to the snappyhexmesh tool or import meshes from other software packages.
as for importing multiple meshes from salome i think you are on the right path with creating two separate meshes. if you mesh the contacting surfaces (2-D sub-mesh) first i believe that the two surface meshes will align to each other. you will then have to suck the two files into one openfoam case. I am currently attempting to do this and will post my results if i am successful. if anyone has any step-by-step processes for this it would be very helpful to see.
thanks
tom
thomasnwalshiii is offline   Reply With Quote
Old   July 26, 2012, 19:45
Post suitup:
Randy
raniisc14 is on a distinguished road
suitup: have a look at the *.setSet file in chtMultiRegionSimpleFoam tutorial...it may answer your question...not sure myself
raniisc14 is offline   Reply With Quote
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation Zeppo OpenFOAM Running, Solving & CFD 16 May 18, 2017 18:04
Thermal Analysis Problem ChristianGermany ANSYS 1 September 26, 2015 13:42
Thermal Analysis Problem ChristianGermany ANSYS 0 September 23, 2015 18:52
[ICEM] Meshing Problem ? Leifheit ANSYS Meshing & Geometry 3 December 4, 2014 18:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
