Home > Forums > OpenFOAM Meshing Format & General Technical
Unspecified boundary types in the grids created employing Pointwise
Old   February 2, 2010, 06:30
Default Unspecified boundary types in the grids created employing Pointwise
Arash Eslamdoost
arash is on a distinguished road
When using the revolve or extrude mesh in Pointwise, often some internal faces are created in the internal field which at the end remain as unspecified boundary types. These types of boundaries are problematic in OpenFOAM. Removing these unspecified boundaries results in removing the blocks sharing any of these certain boundaries (patches).
According to this, would you please let me know whether any of you have had similar problem or not? If so, how did you manage to fix that?
BTW, its is possible to remove such unused patches in GAMBIT without causing any other changes in the created grid; but, how should fix this just using Pointwise?
Regards,
Arash
arash is offline   Reply With Quote
Old   February 2, 2010, 19:09
Post Try Grid, Merge... Before Extruding
rmatus's Avatar
Rick Matus
rmatus is on a distinguished road
If you have unspecified internal faces in an extruded block, it most likely means the domains you started the extrusion from had some gaps between them. (Unmerged connectors in Pointwise-speak.)
You can easily check this by going to the Grid, Merge... panel. If there are gaps they will be outlined in red, and you can use the tools in Grid, Merge... to heal them.
Once they are merged, you can do the extrusion and there should be no unspecified internal faces.
rmatus is offline   Reply With Quote
Old   February 2, 2010, 21:16
Arash Eslamdoost
Hi Rick,
Of-course, that could be a reason but the case I'm talking about is rather different. To be more clear, just imagine a meshed rectangle. If you rotate this rectangle about one of its axis 360 degrees to create a cylinder, you'll find that finally there is a face inside the field which is exactly located on the axis of rotation (I don't know if it is right to call that a face!). This is the unspecified boundary type which I mean. If you remove that face the entire block would be disappeared.
Old   February 3, 2010, 10:31
Default Try setting a cyclic boundary condition
rmatus's Avatar
Rick Matus
Sorry, I was imagining the problem incorrectly. There is some discussion in this thread about the boundary conditions to use on a pole (singularity) as you have in this axisymmetric case. It looks like you should use a cyclic bc on the pole face.
To do that in Pointwise, go to the CAE, Set Boundary Conditions... panel. Click on New and then double click in the Name field of the new entry in the Boundary Conditions table to type whatever name you want to give that BC. Double click in the Type field and when the pull-down activates choose Cyclic for the BC type. Finally, select the face you want to apply this BC to from the display window and then click on the box in the Set column of the table to apply this BC to that face (or faces if you picked more than one).
Hope this helps.
Originally Posted by arash View Post
Hi Rick,
Old   February 9, 2010, 10:35
Arash Eslamdoost
Rick, thanks for your instructions; now it's working.
Old   February 9, 2010, 10:56
rmatus's Avatar
Rick Matus
Arash, happy to hear that worked.
gambit, grid, openfoam, pointwise, unspecified boundary type
Thread Tools
Trackbacks are On
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
Free Boundary Flows on Unstructured Grids George Main CFD Forum 8 March 5, 2002 13:10
Boundary Layer created by Euler Solvers Jim Main CFD Forum 31 November 18, 2001 00:18
Boundary conditions on unstructured grids Chan K I Main CFD Forum 7 January 12, 2001 08:42
