Home > Forums > OpenFOAM Mesh Utilities
stitchMesh -perfect - tolerance error of 2 identical faces
Old   July 16, 2012, 05:30
Default stitchMesh -perfect - tolerance error of 2 identical faces
Hannes
Hanno is on a distinguished road
Hi Foamers,
after reading all stitchMesh regarding threads, i decided to start a new one. I meshed 2 parts of a rectangular channel with blockMesh and now im trying to merge the meshes. mergeMesh works with no problem, and after it, i got 2 regions in the mesh and some non-aligned edges.
So i go to stitchMesh next, but it aways complains about:
--> FOAM FATAL ERROR:
Points on patch sides do not match to within tolerance 1.1156e-06
    From function perfectInterface::setRefinement(polyTopoChange& ref) const
    in file perfectInterface/perfectInterface.C at line 220.
FOAM exiting
and
Searching started from:46536 in pts1
    Compared coord:(0.123884 0.0725446 0.0357143) with difference to point 0.28485
    Compared coord:(-0.111607 -0.0904018 0.0357143) with difference to point 0.0150151
Compared coord:(0.120536 0.078125 0.0357143) with difference to point 0.285685
Cannot find point in pts1 matching point 14834 coord:(0.101563 -0.101563 0.0357143) in pts0 when using tolerance 1.1156e-06
for every point.
I have checked the 2 faces that shoud be stiched with paraView, they are absolutely identical, the geometry is most simple. The tolerance between the points should be zero, instead its pretty high, as you can see.
I have absolutely no idea whats going wrong here, since the test-case with a very coarser mesh worked perfectly.
Thanks for reading
Hannes.
Hanno is offline   Reply With Quote
Old   November 21, 2013, 06:41
Albrecht vBoetticher
vonboett is on a distinguished road
have you tried without -perfect (=integral)?
vonboett is offline   Reply With Quote
Thread Tools
Trackbacks are On
No layers in a small gap bobburnquist OpenFOAM Native Meshers: snappyHexMesh and Others 6 August 26, 2015 09:38
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 1 June 7, 2012 13:39
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
