Home > Forums > OpenFOAM Mesh Utilities
Contribution a new utility: refine wall layer mesh based on yPlus field
Like Tree24Likes
Old   June 9, 2013, 14:16
immortality's Avatar
Ehsan
immortality is on a distinguished road
OK.
thanks for good clarification!
then it splits only the first cell.
how does it calculates the number of splitts?
and if I change the mesh by blockMesh I have to use refine tool again?
Note: add the option "-overwrite" is you want it to override the existing mesh.
do you mean writing in boundary,faces,cells,...files in blockMeshDict?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 9, 2013, 14:31
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
With this:
refineLevelValue = ceil
                std::log(YpMax/targetYPlusValue)/std::log(scalar(2.0))
Note: "targetYPlusValue" is 1.0 by default, unless specified from the command line.
Yes.
Only affects the actual mesh files.
It does not affect the "blockMeshDict" file, because it's used for creating a mesh, it's not "the mesh" .
immortality likes this.
___
I'll be at OFW11 in Portugal
Old   June 9, 2013, 15:49
Ehsan
and another question.if y+ be 1 for example and we want to increase it to 30 this tool can't be used,can?
Old   June 9, 2013, 15:53
Bruno Santos
Nope. That goes in the wrong direction You have to create the mesh first, then refine it.
You can check post #14 for more ideas: Contribution a new utility: refine wall layer mesh based on yPlus field
___
Old   June 10, 2013, 07:28
Ehsan
Hi
why the first cell height after refining is bigger than second one?
I used
refineWallLayerSmart -basedOnYPlus -targetYPlus .7 -overwrite walls 1.5
Old   June 11, 2013, 05:45
Ehsan
in this version
1) it works on yPMax instead of yPMean.so the maximum y+ in the domain will be lower than specified -targetYPlus that leads more accurate results than the average.
2)also the modification of first cell that was bigger than second cell has done according to Bernhard proposed .C file.
3)also it now accepts float numbers for -targetYPlus like -targetYPlus .5
Hope it be useful.
File Type: gz refineWallLayerSmart_MaxY_stretching.tar.gz (4.2 KB, 69 views)
FrankFlow likes this.
Old   June 18, 2013, 14:11
Ehsan
in what it used to be till now we wanted to maximum yPlus be lower
than targetYPlus (as above post)
now I want minimum yPlus be bigger than
targetYplus.it refines mesh still(when for example minimum of y+ is 200) but min(yPlus)>=30(that uses in high-Re mesh's)
it seems an equation should be changed from max(yPlus)<=target to
min(yPlus)>=target.
I'm using average version now but if anyone could have a look into it too
it will be more accurate.
its nice to modify above post file.
thanks.
Old   July 8, 2013, 07:56
mezomatic is on a distinguished road
in this version
Hope it be useful.
Hello there!
I used your Version of the tool on my mesh but the first cell height ist still larger than the second, just like in your post.
I used
refineWallLayerSmart -basedOnYPlus -targetYPlus 1 Wall 1.15 -overwrite
Did you get different results?
mezomatic is offline   Reply With Quote
Old   July 8, 2013, 11:14
Ehsan
Hi
in my case it works right.
send your mesh to me.
Old   July 9, 2013, 01:56
Hi!
This is my case, it's just a simple 2D BlockMesh...
Old   July 9, 2013, 10:37
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Originally Posted by wyldckat View Post
Greetings to all!
Attached is a modification as requested by Ehsan. It's based on Daniel's original modifications and I changed the following
Thanks Bruno!
Using YpMax seems to me too cruel.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   July 9, 2013, 11:48
Ehsan
Hi!
this is somewhat strange!why you have set number of cells in y-direction to 1!
then you expect what to be refined in y-direction?!
Old   July 9, 2013, 11:51
Ehsan
Thanks Bruno!
thanks for original utility,
in cases we want for example y+<1 its more accurate that maximum value of y+ on cells be lower than 1 too at least I think so if you want to correct my understanding I welcome!
Old   July 9, 2013, 14:02
it works in y-direction.
What do you mean by that? Why would it work in only one direction?
I expect nothing to be refined in the y-direction, it's a 2D mesh and it lies in the x-z-plane...
I'm sorry but I didn't understand your concerns about that, the refinement works just fine (see attached screenshot). Only "problem" is the first cell being larger than the second...
Old   July 9, 2013, 14:39
Ehsan
I had forgotten how it was working.I don't know whats wrong with your case.it ends with a crash.
have you set faces correct?I think maybe there is an issue in blockMeshDict.
Old   July 13, 2013, 15:32
Bruno Santos
Greetings to all!
@mezomatic:
Originally Posted by mezomatic View Post
Hi!
I was not able to reproduce the same error
I ran blockMesh, then yPlusRAS and then the command indicated above:
I used
But I got this message instead:
--> FOAM FATAL ERROR:
targetYPlusValue is larger than max yPlus (0), no need to refine the wall layer mesh.
Or you can use "refineLevel" option to force refine.
Best regards,
Bruno
___
Old   July 13, 2013, 15:44
Hey Bruno,
try running simpleFoam on it first for a few timesteps, so the yPlusRAS tool can compute the y+ values properly. Otherwise it's just zero everywhere (see error message) and as that is already below the desired y+ of 1, there won't be anything refined...
Old   July 13, 2013, 16:15
Bruno Santos
Hi mezomatic,
Uhm... simpleFoam crashed at iteration 538 due to massive continuity problems.
Nonetheless, I checked the y+ values on the wall at the iteration 500... and the maximum value of "y+ = 1e9" is waaaaaaaaaaaay too much! Which means that refining the mesh to "y+ = 1" would require the cells to be so thin near the wall, that... uhm... maybe as thin as an atom? I didn't even do the math... all I know is that checkMesh seriously complains about the resulting refined mesh.
Therefore, I strongly advise you to first make your case simulate without crashing, and only then you should try refining the mesh near the wall
Best regards,
Bruno
___
Old   July 13, 2013, 16:35
Ehsan
as Bruno says I received an error too and it seems your BC's and maybe other settings have a big problem in them!find that first.
Old   July 13, 2013, 16:42
Hmm that's strange... I've got no problems at all running the the case without the refinement. My max y+ is 59.
Maybe there's someting wrong with the files. Here's the case again.
I'm using Version 2.2.0
Thread Tools
Trackbacks are On
Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Native Meshers: snappyHexMesh and Others 11 January 13, 2015 12:47
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
non-smooth mesh Svensson OpenFOAM Native Meshers: snappyHexMesh and Others 11 January 18, 2012 10:13
I wonder, how do I mesh a car? MadsR OpenFOAM Native Meshers: snappyHexMesh and Others 0 May 2, 2011 15:39
Wall mesh refinement based on y+ Hrushi OpenFOAM Mesh Utilities 0 July 22, 2010 03:53
