-   OpenFOAM Mesh Utilities (http://www.cfd-online.com/Forums/openfoam-meshing-utilities/)
-   -   decomposePar results in a weired procBoundary (http://www.cfd-online.com/Forums/openfoam-meshing-utilities/114661-decomposepar-results-weired-procboundary.html)
luliqiang March 15, 2013 05:24
1 Attachment(s)
as you see from the attachment, the procBoundary is not flat. How can i get a flat procBoundary? thank you.
ps. my decomposeParDic as follows.
numberOfSubdomains 5;
method          simple;
simpleCoeffs
    n              ( 5 1 1 );
    delta          0.001;
ngj March 15, 2013 05:28
I you have some specific requirements on the decomposition, e.g. flat processor boundaries, then I suggest that you use the manual decomposition method, where you specify, which processors the individual cells belong to.
It is a quite simple operation, which you could e.g. based on the cell centres, which you can obtain based on
writeCellCentres
Kind regards,
Niels
luliqiang March 15, 2013 06:53
Originally Posted by ngj (Post 414135)
writeCellCentres
Kind regards,
Niels
thank u Niels. :)I got it, with a modified writeCellCentre file. just add a few lines:
forAll(cci, cellID)
    pid = (int)(cci[cellID]/LX);    //cellID belongs to which process
    fprintf(fSrc, "%d\n", pid);    //output
    sum[pid]++;            //sum
the dataFile is:
FoamFile
version 2.0;
format ascii;
class labelList;
location "constant";
object decompDict;
124218    //number of cells
3    // first cell belongs to process 3
0    // second cell belongs to process 0
x    // the cell belongs to process x
2    // last cell belongs to process 2
ngj March 18, 2013 09:43
Hi
This thread has a nice description of how to create the file for manual decomposition:
http://www.cfd-online.com/Forums/ope...computing.html
/ Niels
