MapFields seems hanging
For a grid convergence study I am trying to map the fields from a coarse mesh to a finer mesh with MapFields. MapFields seems however hanging at the statement:
Create databases as time |
I came across the same problem and was able to narrow it down a little bit. Using blockMesh as mesh generator everything works fine as long as only orthogonal cells are refined. Moreover, as long as I refine the mesh along the direction of one of the coordinate axes everything is fine also for nonorthogonal cells. However, I've got cells in the boundary layer with very high aspect ratios (~600) and I would like to refine the mesh in the direction of the wall (which is inclined) and that does not work anymore. I also tried to use mapFields with the option -mapMethod mapNearest in order to overcome any potential problem with the interpolation but it still does not work. Anybody any idea? Best regards Hannes |
I've been having issues with OF230 mapfields command as well,
it meshes and the fields look absolutes fine but I end up getting errors when I run the solver, are you saying that your will not even finish the mapfields proceedure? |
