[mesh manipulation] Problem with stitchMesh: it does not work in meshes with several common patches
Like Tree1Likes
  • 1 Post By arnau1985
Old   June 20, 2013, 12:32
Default Problem with stitchMesh: it does not work in meshes with several common patches
arnau1985's Avatar
Arnau
arnau1985 is on a distinguished road
I am using mergeMeshes and stitchMesh to merge several meshes and to get rid of internal faces, as they are not supported by OpenFOAM. Everything works fine since the patches I am stitching are perfectly conformal and the geometries very simple. However, when I try to stitch more than one pair of patches in the same merged mesh I get the following error (please see the explanatory chart I have attached):
--> FOAM FATAL ERROR:
Face 73125 reduced to less than 3 points.  Topological/cutting error B.
Old face: 2(7938 7982) new face: 2(7938 7982)
    From function void slidingInterface::coupleInterface(polyTopoChange& ref) const
    in file slidingInterface/coupleSlidingInterface.C at line 1795.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/home/arnau/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/home/arnau/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::slidingInterface::coupleInterface(Foam::polyTopoChange&) const in "/home/arnau/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#3  Foam::polyTopoChanger::topoChangeRequest() const in "/home/arnau/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#4  Foam::polyTopoChanger::changeMesh(bool, bool, bool, bool) in "/home/arnau/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
 in "/home/arnau/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/stitchMesh"
#6  __libc_start_main in "/lib/libc.so.6"
Aborted
Just for the record, I delete all the pointZones, faceZones, cellZones and meshModifiers files after running stitchMesh every time. The OpenFOAM version I am using is 2.1.0 and the meshes were originally created with Salome and converted using ideasUnvToFoam.
Thank you very much for your time.
Kind regards,
Arnau.
Chart of mergeMeshes and stitchMesh process: StitchMesh_problem.jpg
arnau1985 is offline   Reply With Quote
Old   June 25, 2013, 09:20
cutter is on a distinguished road
unfortunately I can't help you yet. Just for your information, the same thing has lately been observed and discussed in other threads:
http://www.cfd-online.com/Forums/ope...tml#post183551
http://www.cfd-online.com/Forums/ope...tml#post418651
http://www.cfd-online.com/Forums/ope...mesh-used.html
Maybe you could provide your test case or a minimal working example too.
Good luck!
Cutter
cutter is offline   Reply With Quote
Old   June 25, 2013, 09:49
Default Solution
arnau1985's Avatar
Arnau
Thank you very much, Cutter!
I found a way to work around this problem a couple of days ago (it works at least in OpenFOAM 2.1). I post it in case anybody else experiences the same problem:
Do not ask my why, but for some reason, you have to run stitchMesh with the "-perfect" option. E.g.:
stitchMesh -case {case_name} -overwrite -perfect {master_patch} {slave_patch}
If anybody knows why this happens, please explain it.
By the way, the files *Zones and meshModyfiers in ./constant/polyMesh can be the source of other errors, so do not forget to delete them after every stitchMesh. Besides I have observed that in some OpenFOAM versions all patches, both internal and boundary conditions, have to be defined in ./0 when you stitch meshes.
Good luck!
purnp2 likes this.
mergemeshes, openfoam, stitchmesh
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 09:19
[mesh manipulation] mirrorMesh and undoing the joining of patches chegdan OpenFOAM Meshing & Mesh Conversion 3 October 21, 2015 09:09
Problem exporting big meshes from ICEM to Fire Emil CFX 0 October 10, 2008 14:06
Divergence problem on different meshes Harry Main CFD Forum 2 September 26, 2006 01:23
STAR HPC. Problem with COMMON BLOCK Denis Siemens 0 April 4, 2003 08:33
