[Salome] 2D Moving Mesh - Salome to OpenFoam WorkFlow
Like Tree1Likes
  • 1 Post By ADGlassby
Old   August 23, 2013, 06:59
Default 2D Moving Mesh - Salome to OpenFoam WorkFlow
Andrew Glassby
ADGlassby is on a distinguished road
After a lot of trial and error and going to and fro between forums I have come up with a workflow for preparing a mesh for a 2D moving mesh problem.
I have included a link to the PDF of the workflow for anyone who might be interested. I have made it fairly generic but there is sufficient detail in it to enable someone to follow it through with small amounts of additional research (mainly referring to the Salome tutorials).
I hope that this might be useful as the whole meshing subject was very bewildering to me in the first place and the learning curve can be staggering.
As far as CAD is concerned, as long as your CAD package can export a flat .iges file then you're in business. I used ViaCAD on a Mac for interest.
Please follow this link as the pdf file is a little bigger than I'm allowed to upload:
https://dl.dropboxusercontent.com/u/...ing%20Mesh.pdf
Best Regards
Andrew
startingWithCFD likes this.
ADGlassby is offline   Reply With Quote
Old   August 23, 2013, 07:01
Andrew Glassby
I might add that the moving mesh I was trying to create was a rotating zone, a little like the tutorial mixerVesselAMI2D, before I moved onto the model I am trying to create.
Regards
Andrew
[Salome] Problems for creating mesh in salome to OPENFOAM bye bye my blue OpenFOAM Meshing & Mesh Conversion 8 December 5, 2023 00:57
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[Salome] Mesh Salome 7.3.0 to OpenFoam Ahadi OpenFOAM Meshing & Mesh Conversion 5 July 1, 2014 10:11
[Salome] OpenFoam case and salome mesh marialiste OpenFOAM Meshing & Mesh Conversion 1 December 4, 2013 14:56
Moving unstructured mesh with changing topology meaton OpenFOAM Running, Solving & CFD 6 April 27, 2008 07:56
