[snappyHexMesh] geometry location problem
Old   May 31, 2014, 11:30
Default geometry location problem
rogibear is on a distinguished road
I'm trying to use snappyhexmesh for a simple ahmed body simulation. I have the geometry in stl form however the location properties don't seem to work on it. Therefore the refinement box isn't in the correct place.
If you need any more info/dicts let me know and i'll post them as soon as I can
rogibear is offline   Reply With Quote
[ICEM] problem export 2d geometry Marcuse ANSYS Meshing & Geometry 7 January 26, 2015 14:34
Problem with building geometry - concentric cylinders Rhoddwen OpenFOAM Pre-Processing 9 December 17, 2014 10:02
Problem with geometry - concentric cylinders Rhoddwen OpenFOAM Running, Solving & CFD 0 December 15, 2014 09:22
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 22:15
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
