Creating an openfoam mesh for paraview using openfoam designer?
So far I tried this much.
I used the template called cavity inside the icofoam folder and copied it to a folder called CFD. I then tried to create the mesh by doing mesh utilties->generation->blockmesh-> right click and start which generates these files inside of constant/polymesh/ boundary, faces, neighbour, owner, points now I'm not sure how to generate a .foam file to open in paraview, any ideas? |
I did try using the echo command in windows as this thread says and then tried opening it with Paraview but then it crashed.
http://www.cfd-online.com/Forums/ope...ndows-7-a.html #10 on this thread maybe the answer, http://www.cfd-online.com/Forums/ope...r-windows.html |
Regarding your question "now I'm not sure how to generate a .foam file to open in paraview, any ideas?", if you are still interested take a look here: http://www.fm.energy.lth.se/fileadmi...rExercise1.pdf go to page 10. Simply, you have to create an empty file with *.foam (or *.openFOAM depending what version of ParaView you have on computer) extension in your case folder. For OpenFOAM under Windows, you can download version OpenFOAM 1.5 installer from here: http://sourceforge.net/projects/openfoam-mswin/ Mihai |
