June 2, 2014, 16:43 |
mapFieldsIssueOpenFOAM230
Jason Pearl
Rep Power: 12 |
I'm a Graduate student using openfoam for my research, I've been using openfoam220 for over a year and just switched to openfoam230. the mapFields utilities has been revamped. I am trying to map to a refined mesh but it has been giving me some serious issues in openfoam230 i first tried mapFields ../(directory) -consistent which worked well with openfoam220. The mapped fields produced were garbage and the sim crashed immediately. I then did some digging online and found out that cellVolumeWeight option became standard in 230 so I tried mapFields ../(directory) -consistent -mapMethod mapNearest this gave me nicely mapped fields for p T and U but when I try to run the solver rhoCentralFoam I get this error almost instantly: Code:
jmpearl@syzygy:~/OpenFOAM/threeDim/flat45deep80trunc/250kPaR1$ rhoCentralFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : rhoCentralFoam Date : Jun 02 2014 Time : 16:14:37 Host : "syzygy" PID : 6132 Case : /home/jmpearl/OpenFOAM/threeDim/flat45deep80trunc/250kPaR1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0.002 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport polynomial; thermo hPolynomial; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Creating turbulence model Selecting turbulence model type laminar fluxScheme: Kurganov Starting time loop Mean and max Courant Numbers = 2.788601e-05 0.0007670006 deltaT = 5.99988e-12 Time = 0.002000000006 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 diagonalPCG: Solving for Ux, Initial residual = 3.507427e-08, Final residual = 5.697393e-11, No Iterations 1 diagonalPCG: Solving for Uy, Initial residual = 1.090408e-07, Final residual = 1.215486e-10, No Iterations 1 diagonalPCG: Solving for Uz, Initial residual = 7.464901e-08, Final residual = 1.793315e-11, No Iterations 1 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::polynomialTransport<Foam::species::thermo<Foam::hPolynomialThermo<Foam::perfectGas<Foam::specie>, 8>, Foam::sensibleInternalEnergy>, 8> > >::he(Foam::Field<double> const&, Foam::Field<double> const&, int) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so" #4 Foam::fixedEnergyFvPatchScalarField::updateCoeffs() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so" #5 Foam::fvPatchField<double>::evaluate(Foam::UPstream::commsTypes) in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/rhoCentralFoam" #6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/rhoCentralFoam" #7 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/rhoCentralFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/rhoCentralFoam" Floating point exception (core dumped) any suggestions ? how does one successful map consistent fields in the new version openfoam230? |
compressible flow, map fields, mapfields, printstack, rhocentralfoam |
