[mesh manipulation] mirrorMesh utility preserving regions
Old   August 25, 2014, 11:13
Default mirrorMesh utility preserving regions
Alex
zfaraday will become famous soon enough
Hi foamers,
Some time ago I was working in a case where I used a quarter of a cylinder as a base geometry because of symmetry. My geometry was made up of some regions defined via blockMeshDict (naming the diferent blocks) and splitted afterwards using splitMeshRegions utility.
Now I want to re-use that geometry but I need the whole cylinder instead of only the original quarter cylinder. To do that I thought about using the utility mirrorMesh but it has some limitations to suit my needs. It mirrors the mesh perfectly, of course, but it doesn't respect my region specification. I mean, the original regions specified in the blokMeshDict file keep being part of the original quarter of cylinder, but they are not extended to the whole cylinder after mirroring the quarter. Thus, in the end I have my original regions (defined within the first quarter of the cylider) plus one more region containing the rest of the cylinder generated by the utility.
Is there any utility (or option within the mirrorMesh utility) to mirror my original geometry taking into account the region specification?
Thanks in advance.
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   November 7, 2016, 21:51
Gianluca
ninoleum is on a distinguished road
Hi Alex, I'm experiencing exactly the same problem, of course related to another geometry. Did you find a solution so far?
I hoped also mirrorMesh had the '-region' option so that I could be able to mirror each region mesh one by one after processing the global mesh with splitMeshRegion but it has not this option.
Thank You
Gianluca
ninoleum is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
[snappyHexMesh] multiple regions Tobi OpenFOAM Meshing & Mesh Conversion 56 March 29, 2020 04:53
Determining the calculation sequence of the regions in multe regions calculation peterhess OpenFOAM Running, Solving & CFD 4 March 9, 2016 03:07
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 16:47
chtMultiRegionFoam different properties in (fluid) region(s) volker1 OpenFOAM Pre-Processing 3 February 4, 2015 06:46
