[mesh manipulation] Create patches from a very complex geometry
Old   January 8, 2015, 07:47
Exclamation Create patches from a very complex geometry
Julie Correncon
CoSponge is on a distinguished road
Hello everybody,
I am wondering if it is possible to create patches and different region automatically from a .stl file.
For a simple geometry I tried to isolate the faces belonged to the different regions I'd like to have in the .stl file manually. It works perfectly
But now I have a very complex geometry, isolating the region is impossible by hand.
AutoPatch doesn't work, because it isolates some single points as a region (the mesh is not perfect) or the whole geometry, depending on the angle.
I know I could do it with the tool createPatches or making different blockMesh regions for each patch.
Does anyone knows the best option??
Thanks in avdance for the help,
Julie
CoSponge is offline   Reply With Quote
Old   January 11, 2015, 17:57
M. C.
student666 is on a distinguished road
Have you tried topoSet dict?
SurfaceToCell allows you to exctract cellSet from a stl file, then you can turn it into a patch with topoSet as well, try have a look here.
https://openfoamwiki.net/index.php/TopoSet
Bye
student666 is offline   Reply With Quote
Old   January 12, 2015, 05:39
Thumbs up Hi, thank you a lot for the reply!!!
Julie Correncon
Can I ask you to explane me topoSet? For example, what is the difference between faceSet, cellSet, ecc? I mean, do they work one after the other or do I have to choose?
I'm a bit confused...
Cheers,
Julie
Old   January 13, 2015, 04:33
M. C.
Toposet is a dictionary that allows you to define into your polymesh folder a set of faces, points, ecc..or faceZone, cellZone as well.
You're not supposed to follow a hierarchical path, so if you need to define a set of faces, you have not to define a set of points previously.
My fault on my previously post, I think you'll have to use createPatch dict after you defined faceSets.
So the workflow should be:
first you define your face sets with topoSet
Second you use createPatch to define the patches for you purpose.
If you still have confusion what faceSet, cellSet, pointSet are, think they are a collection of entities.
Bye
Old   January 14, 2015, 12:35
Default Perfect, it works ;)
Julie Correncon
Perfect, it works
Thanks a lot!!
Old   June 9, 2015, 08:51
Default Fan modelling
Alex Lee
Alex Lee is on a distinguished road
Dear all,
Does any one know how to create a cyclic (circular) patch to mimic a pressure jump in the T-Junction tutorial using a STL patch ?
Thanks.
Alex Lee
Alex Lee is offline   Reply With Quote
complex geometry, patches, regions, stl file
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Cyclic boundaries in OF 21x morard OpenFOAM 25 May 13, 2013 22:35
[ICEM] How to deal with a really complex geometry mountaineer ANSYS Meshing & Geometry 1 February 21, 2012 11:57
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 09:03
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
